Paint/Body Corvette Materials, Techniques, and How To
Adding another tank in line to compressor tank
Old 08-03-2014, 02:29 PM
TWINRAY
TWINRAY's Avatar
Default Adding another tank in line to compressor tank
Would I be accomplishing anything if I connect a 10 gallon tank in-line to my compressor which has a 12 gallon tank? Would my compressor cycle any more or less - or would it stay the same? Any effect on cfm airflow? Thanks
Old 08-03-2014, 03:40 PM
porchdog
porchdog's Avatar
a little more volume but it will disappear fast. the size of a tank equates to the size of the pump.
Old 08-03-2014, 06:21 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
Think of it like this. You have storage tank the size of a 55 gallon drum...and a compressor that has a piston the diameter of a soda can....then you get the idea of hooking up an 1000 gallon tank to it because it has SOOOOO much more air space....which is correct....but it makes you compressor run longer....and as 'porch dog' stated...the pressure would drop rather quickly....and thus makes you compressor run longer to fill up the added tank
A larger compressor is what is often needed...because if you small compressor is running A LOT...it is getting hot and thus your air is HOT and thus all the 'frappis' you need to cool down the air so you can remove the moisture so you do not have it spitting water on your paint job when painting.
DUB
Old 08-04-2014, 10:26 AM
TWINRAY
TWINRAY's Avatar
Thanks PD and DUB for the explanation which is now clear to me.
Regards, Fred
Old 08-04-2014, 10:34 AM
porchdog
porchdog's Avatar
i bought my 5 hp and a 10 hp used and rebuilt in 84 . still use the 5 hp which i had freshened up i 98 . you can buy rebuilt for much less and usually get a better unit.
Old 08-04-2014, 11:35 AM
TWINRAY
TWINRAY's Avatar
Thanks for the advice. I think the Lowes 3.7 hp with a 60 gallon tank is a simple and easy answer for me with only 2 major projects to do.
http://www.lowes.com/pd_54284-1126-V...56&CAGPSPN=pla
Old 08-04-2014, 01:59 PM
Dave Tracy
Dave Tracy's Avatar
Check the needs of your gun for SCFM.
To Adding another tank in line to compressor tank
Quick Reply: Adding another tank in line to compressor tank
