Engine compartment
I feel that you HVLP gun will work...I can not see why it would not.
IF you go the PPG black epoxy route (DP90LF)...you might want to thin it a bit with some of there DT reducer ( comes in different temperature grades for the temp at the time of application)..and TEST IT FIRST..so you can see how well it lays down and does not go on excessively orange-peely. I also prefer to use the DP-401LF hardener....which REQUIRES an induction period of about 1/2 hour before you can spray it.
SEM offers a lot of good products for this also. The DP90LF...when dried has a very good look and is very acceptable and close to the sheen of the factory black. It will depend on how picky you are.
I can not comment on the Campbell acrylic lacquers...I do not use them or ever have used them. I know I would NOT want a lacquer paint for this application area due to lacquer is extremely solvent sensitive and can get damaged easily.
DUB
DUB
Roger
