Paint/Body Corvette Materials, Techniques, and How To
1989 windshield replacement
Old May 17, 2015 | 08:58 PM
mlm0's Avatar
mlm0
Default 1989 windshield replacement
I hope this is right section
I have to replace windshield and want to know if the trim around the windshield, which looks like its plastic or metal, can be reused by professional installer or do I have to buy new. It's appears to be very costly
Old May 18, 2015 | 06:00 PM
DUB's Avatar
DUB
YES...I APPLAUD you...this is the RIGHT SECTION.
If it is CAREFULLY removed it can be re-used. Also..be aware that there is a thin plastic piece that is attached to the underside of these moldings so it protects the edge of the windshield. AND.....there is a closed cell foam tape that is also applied to the backside of these moldings. When I replace the foam tape...I use the truck bed camper seal foam tape.
I also apply this same truck bed foam tape on the backside of the weatherstrip track for the pillars also.
Whatever you do...do not let the installer pump urethane in and slap on your moldings instead of using the correct tape. You will regret it if they do.
DUB
Old May 18, 2015 | 09:04 PM
mlm0's Avatar
mlm0
Thanks so very much. I knew if anyone would know it would be you
Thanks again
Mike
To 1989 windshield replacement
