Paint/Body Corvette Materials, Techniques, and How To
C5 bumper bowed inward
Old Aug 15, 2015 | 08:03 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Default C5 bumper bowed inward
After a low speed impact, my front bumper is dented inwards (I idled into the trailer hitch of a car that stopped short on an entrance ramp to a highway)
I'm curious if I hit the backside with a heat gun if I can re-mold the surface back into it's original shape or if this will cause more damage.
Old Aug 15, 2015 | 05:38 PM
DUB's Avatar
DUB
A photo would do much better than a brief description. But...YES...heat can allow you to re-shape the urethane.
I can not comment on if it can cause more damage...because if the paint has spider cracked...then it might....if it has been re-painted...this can also cause for a problem due to the paint can possibly delaminate due to improper prep on the bumper when it was re-shot.
DUB
Old Aug 23, 2015 | 10:24 AM
Hi Volts Z06's Avatar
Hi Volts Z06
Just an FYI- after my C5 race car went into the wall at over 120 mph, I had the same problem and removed it in preparation for replacement. I placed it outside for the garbage and to my surprise a few days later, the heat of the sun actually let it find its way back into place.
Old Aug 23, 2015 | 11:11 AM
TheRadioFlyer
Supporting Vendor
I found the structural damage I remembered actually cured itself. I bend the bumper support piece back into place and apparently the bumper is now the correct shape....now just need to fix the paint and replace the hood....
To C5 bumper bowed inward
