Paint/Body Corvette Materials, Techniques, and How To
Prep after electrolysis
Old Oct 13, 2015 | 11:18 PM
Jbabek's Avatar
Jbabek
Default Prep after electrolysis
A little guidance please...
I made a electrolysis tank and de-rusted the entire front end and rear end of my 60 Corvette. From the tank, i wiped them in phosphoric acid to prevent flash rusting. The parts look great and are rust free. They do have some stains on the surface, but there is no rust.
Can I spray a good epoxy primer over this surface, or should it be blasted? Has anyone done this?
Old Oct 14, 2015 | 06:10 PM
DUB's Avatar
DUB
Wise move would be to call the manufacturer of the epoxy primer you plan on using....due to you did not mention it in your post. Talk to their tech department and see what they recommend/suggest.
the reason is when I use phosphoric acid to clean parts...I get them clean...wash off with water and dry very well and immediately prime.
On some parts I will media blast them because even though I removed the rust....I still do not like the way the metal looks.
Sometimes I just put the parts in the bast cabinet and not even waste the time on trying to remove the rust due to my media will make short work of it.
So...it all depends.
DUB
Old Oct 14, 2015 | 07:03 PM
porchdog's Avatar
porchdog
you will need to reapply the acid and rinse while it is still wet . like dub said dry it and epoxy it . a true epoxy will loose adhesion if applied over acid .
To Prep after electrolysis
