Paint/Body Corvette Materials, Techniques, and How To
door rivets question
Old Feb 26, 2016 | 07:19 PM
DEAN66's Avatar
DEAN66
Default door rivets question
Have a slight movement at the pass. door rivets,not a lot but more than driver side. does the door skin need removed to replace ? any instructions on how to install rivets [ 66 coupe] --tks.
Old Feb 27, 2016 | 05:42 PM
DUB's Avatar
DUB
Where are the rivets that you are feeling that are loose. I KNOW they are in the door....BUT where in the door....by the hinge entry areas...at the bottom of the door....where?
DOOR SKIN??? what part do you mean??? The inner door panel.....OR....the painted outer door skin????
DUB
Old Feb 27, 2016 | 06:24 PM
DEAN66's Avatar
DEAN66
DUB
by the hinge entry area,and i was refering to the outer skin . With more research i found out that new holes could be drilled between existing rivets,which would work for me
To door rivets question
