Paint/Body Corvette Materials, Techniques, and How To
Rust removal from painted surface.....
Old Sep 17, 2017 | 08:05 AM
Wee's Avatar
Wee
Default Rust removal from painted surface.....
This may be a little off topic because corvette bodies are of course fiberglass so rust there isn't an issue, but I thought it might help on other things. I have an old 7UP machine that I'm working on and didn't want to have to paint it. I was just looking to clean it up and remove some of the rust without taking all the paint and logos off. I used a prep & etch product that contains phosphoric acid and it turned out pretty well for an almost 60 years old machine.
Before....
After....
Brian
Old Sep 17, 2017 | 08:31 AM
dmaxx3500's Avatar
dmaxx3500
what product did you use?,how long did you leave it on?
Old Sep 17, 2017 | 08:39 AM
Wee's Avatar
Wee
I'll post a more in depth write up including the product I used after we get home from Church today.
Brian
Old Sep 17, 2017 | 01:29 PM
Wee's Avatar
Wee
Here is the product I used....This gallon jug was bought about 4 years ago so I'm not sure if they still sell the same version as this or not and I also do not know if it loses strength over time. I first cleaned it with soap and water and let it dry....It works better on flat surfaces....I just sprayed it on, make sure to coat the entire surface...I used gloves and spread it around.... I used a rag to wipe it down after it set for awhile... It takes 10 to 15 minutes and areas like the small door with the glass window took 3 or 4 cleanings. Watch the fumes.
Brian
Old Sep 17, 2017 | 07:29 PM
porchdog's Avatar
porchdog
i use milkstone remover on patina cars. what looks like toast will clean up pretty well .
To Rust removal from painted surface.....
