Paint/Body Corvette Materials, Techniques, and How To
Masking Tape
Old Dec 19, 2017 | 11:28 PM
13611's Avatar
13611
Default Masking Tape
Hi all. I'm sure this has been covered but I can't come up with any solid answers searching threads so here goes. I see a lot of pictures here where people are doing fiberglass repairs and there's masking tape on the body that winds up under the fiberglass that's applied. What is that for?
Thanks,
Jason
Old Dec 20, 2017 | 07:39 AM
SB64's Avatar
SB64
Default tape
Are they using it for backing Jason when they apply the cloth and not removing it?
RVZIO
Old Dec 20, 2017 | 08:52 AM
929nitro's Avatar
929nitro
It is used as a sanding guide sometime. I have seen people use it when glassing in seam lines. When they sand they know when they hit the tape they are getting close to height of the adjacent body panels.
Old Dec 20, 2017 | 05:10 PM
DUB's Avatar
DUB
And the tape like rvzio mentioned is a backer so when any repairs are being done the fiberglass resin and or body filler will lay against it and thus the tape is help in got possible crate a surface once th fiberglass /resin and body filler sets up.
And I do remove the masking tape when completed.
I show it in this thread.
https://www.corvetteforum.com/forums...-drag-car.html
DUB
LTwannaB's Avatar
LTwannaB
Jason,
Like RVZIO said, I use the masking tape as a backer while laminating over holes or areas that need to be built out. Pre-saturate the mat/cloth with your resin and place directly against the masking tape. The adhesive on the masking tape is not doing anything to hold the wetted mat. Once the lamination is cured, remove the tape and continue with laminating the other side.
This thread shows the process I am using.
https://www.corvetteforum.com/forums...de-of-smc.html
Also, as 929nitro said, masking tape can be used to define an area where you don't want resin to run down over as you are laminating.
Look at post# 24 in the above thread.
Dan
Old Dec 20, 2017 | 05:12 PM
LTwannaB's Avatar
LTwannaB
Dub,
You are a faster typer than I am!
Dan
Old Dec 21, 2017 | 03:12 AM
13611's Avatar
13611
Thanks guys. It was seeing the tape on the pretty side of the body that had me guessing. Thanks for clearing that up.
To Masking Tape
