Paint/Body Corvette Materials, Techniques, and How To
Paint question.
Old Dec 22, 2017 | 03:55 PM
lastcaveman's Avatar
lastcaveman
Default Paint question.
Will a 5 Star 2K High Build Urethane Primer Work with
High Gloss Candy Single Stage Acrylic Enamel? and how many gallons of paint would be needed to paint my 74 coupe? Thanks.
Old Dec 22, 2017 | 05:55 PM
DUB's Avatar
DUB
https://www.paintforcars.com/maxx-fi...activator.html
It says that ANY paint system can be applied on it.
AS for a single stage CANDY acrylic enamel makes no sense to me.
You have to understand that when you use the word CANDY...it means something VERY SPECIFIC and is not just the name that use to give paint color...but rather it is a specific paint system. Mainly a tri-stage.
So...a true CANDY paint takes a base color that the car is painted first...then the CANDY which is a translucent paint is applied on it...then CLEAR is applied on it.
SO....there is no way for me to tell you how much paint you need until I really know what you are using.
And this can also change GREATLY due to the type of paint gun you use during the paint job....and than...having to take into consideration how fast the color actually covers due to many colors are weak in toner strength and may taken MANY coats to get to full hiding.
I am not trying to tell you anything on how to do what you want to do...but I know that if you were at my shop and wanting me to apply a singe stage candy on your car..I would not. For the obvious reasons I had just mentioned where the candy needs to have a clear applied on top of it to protect it. Or at least that is how I do it...and others may not do it that way.
DUB
Old Dec 23, 2017 | 12:25 AM
lastcaveman
my bad It is Candy apple red in color only
High Gloss Candy Apple Red Single Stage Acrylic Enamel Car Auto Paint
Old Dec 23, 2017 | 06:00 PM
DUB's Avatar
DUB
Your 'bad' again....you are still not understanding because you are using the word 'candy apple' again.
So...it is a red paint that is being called 'CANDY APPLE'????....correct?
Basically a red paint like a fire engine?
DUB
Old Dec 24, 2017 | 01:21 AM
lastcaveman
[QUOTE=DUB;1596239916]Your 'bad' again....you are still not understanding because you are using the word 'candy apple' again.
DUB[/QUOTE
Single stage acrylic enamel color unimportant. Will 2 gal do it ?
Old Dec 24, 2017 | 05:45 PM
DUB's Avatar
DUB
I have no clue...go out and buy 2 gallons if you want. You can;t even ask easy questions....
Not knowing what you are using...buy 2 gallons so you have a lot left over.
Not knowing the ratios of reducer and hardener and IF the toners/pigments in the paint you plan on using are strong and cover fast. Who knows...no information.
Without any information....it is all guessing.
I tried to help...
DUB
Old Dec 25, 2017 | 12:32 AM
lastcaveman
Ya, thanks
Old Dec 25, 2017 | 11:14 AM
porchdog's Avatar
porchdog
i believe the color is the old mustang color and as dub said without knowing the brand there is no telling. some cover well others are **** water thin and take 6-8 coats to cover. the cheaper the paint the more it takes in most cases .
i buy 2 gals for every job . usually have 1/2 gal letft. pour it into qrt cans and send with customer for future repair .
Old Dec 25, 2017 | 01:00 PM
lastcaveman
Thank you Porchdog, two gal. I will get.
Old Dec 26, 2017 | 09:24 AM
porchdog's Avatar
porchdog
mix it all together to even the color then pour into qrt cans . the last qrt in a gal usually does not match at all .
Old Dec 26, 2017 | 03:41 PM
lastcaveman
This is the paint at 99.95 a gal I think it`s pretty cheap but it covered well on the T-tops. I bought a quart to try it out they only have 7 gal. left out of this batch so I need to buy it now even though it will be awhile before I actually start painting. Thanks again. TheMix is 8 Parts Paint, 1 Part Hardener, and 2 Parts Reducer. photo didn`t work but this is the mixture
Old Dec 26, 2017 | 05:44 PM
DUB's Avatar
DUB
So...a gallon of raw paint will make 5 1/2 quarts of shootable paint.
Not knowing how FAST the color went on in regards to the hiding effect of it....and the type of paint gun you are using....because paint gun design DOES make a difference in the percentage of paint transfer.....so...you have to figure it out on how much it took for you to shoot the T-tops and figure it out from there.
I think your 2 gallon 'quess-timate' should do... Heck that is 11 quarts of shootable paint. And I know with my paint gun...I could get by with less than that or at least have a lot of extra left over paint.
DUB
Old Jan 5, 2018 | 07:01 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by porchdog
I believe the color is the old Mustang color.
It may be deceiving to an experienced painter, when using the term "candy", that it isn't a 3 stage paint. But yes, Ford did call their bright red, as used on the '68-'69 Mustangs, 'candy apple red'. I did a fender repair for one of my buddies, on his Mustang, back then, and I remember that was what the color was called.....
Old Jan 5, 2018 | 05:06 PM
DUB's Avatar
DUB
And I am aware of that...but as you know...the color is not a 'candy' paint like used in tri-stage paint jobs. This is where what the color was called.... can effect how a response can be given and needed to be clarified.
DUB
To Paint question.
