Repair Suggestions
Repair Suggestions
2016 C7 Long Beach Red
Cosmetic repair suggestions needed for minor damage caused by running over hotel parking lot exit curbing. Don't want to replace the right front fender. Northern VA
Not knowing if this is the full extent of the damage due to no other photos are given. So if this corner curves under to give it strength at the corner. I am having a hard time in advising you what to do.
I would have to guess that using some fiberglass mat and resin for SMC is needed to build out on this shaved off corner.
Then the appropriate steps to get the lamination covered and looking good so primer and then the paint can be applied.
DUB
DUB
Z06LMB (10-31-2018)
Having someone toy try to spot in this repair without fully clear coating the fender is possible...BUT...the chance that you can see the line where the fresh clear stops is also HIGHLY POSSIBLE,....which is why clearcoating the full panel is a common practice whenever possible.
AS for having to getting into the door. I can not see that but I am not looking at your car personally and I may see something that is not seen in the photo.
The $425 estimate seems to be more in line with what I can see it will take.
What may not be known by people who do not do this type of work for a living is the amount of time to prep the panel and make sure all is correct for excellent paint adhesion Then making sure the color that is mixed will work as being able to be blended into the existing paint. Because 'thinking' that if the paint is mixed to the prime color formula is going to be the exact color is an incorrect way of thinking. This is because often times there are 'variants' to a color which means that the factory did not get them all the exact same.
DUB
DUB
Clearcoat Mismatch Fear
I fear the new clear coat won't match the rest of the car.
One guy said he uses PPG 2020.
DUB
DUB
If you are concerned about the texture in the clear...that has a lot to due with how it is applied and prepped prior to the clear beign applied.
I have never had anyone tell me that the clear does not match in texture or shine....Often times I buff/polish an adjacent panel to make the panel I shot with fresh clear now be not so noticeable and the adjacent panels had the shine brought up on them and feather out the buffing so I am not buffing the entire car due to its previous lack of paint maintenance..
DUB
By you posting a photo of your car... you should not have any concerns about clear not being shiny enough fi the painter know the product he uses.
Just make sure you let him know about what you use on the clear due to some of the products that an be applied on paint can have silicone and other types of new age penetrants for paint in them which makes the prepping process change so the paint/clear will actually stick.
If this product is anything like 'Cilajet' it DOES require a process to get it to be removed due to being so slick.
I can say that it would be worth his time to investigate IF there is s specific process to get his product you use to come out of the paint surface so other materials can mechanically or chemically bond to it. If he does not...there is a chance the paint can fly off in a sheet.
The reason I mention this was due to back in the day the dealerships would apply (and still may do) a polyglycoat product on the paint which will not allow paint to stick unless it has been removed. I got bit by this on several jobs and have learned my lesson not to ASSUME ANYTHING when it comes to what a person applies on their car. I need to see the product in the can/bottle that they use.
DUB
DUB
dfettero (10-30-2018)
I guess it looked like this.
DUB
DUB
