#3 Mounting Bolt PS Access Panel
IF when you push on this panel and it goes back in the same area where it separated from...You can simply clean and scuff the exposed fibers and apply Vette Panel Adhesive and that will bond it back and hold.
OF this separation is FRESH adn just happened so the fibers have bot been exposed to crap and crud...you can simply put the VPA on it and bond it right back together due to the rough exposed fibers will work as a good surface for bonding. Maybe just scuff off some loose fibers ....if any.
IF you do not want to go out and buy a quart of BPA for this. Then using a 2 part epoxy adhesive is needed and that may or may not cost more than the VPA will cost.
Using the small epoxy adhesives from a hardware store is up to you. Not saying that they will not work...but I do not need them due to having the correct stuff on hand at my shop.
DUB
DUB
DUB
DUB
