Paint/Body Corvette Materials, Techniques, and How To
Modern Paint Formulas for Old Codes
Old Jun 9, 2019 | 12:59 PM
Double-O's Avatar
Double-O
Default Modern Paint Formulas for Old Codes
BTW, is there a source to convert the old lacquer formula to a 2 stage BC/CC? I found formula codes on this link.
http://paintref.com/cgi-bin/colorcod...ette1972WA4149
I have access to a Sherwin Williams paint system (first choice as lowest cost for me) and the code does not convert to a modern formula. It has an 'L" in the code so likely the original lacquer code. Years ago I used the DuPont Color Library. They converted old lacquer codes to modern BC/CC formulas. I can also take off the fuel door and take to any jobber, but was thinking if they could start with a converted modern formula, mix first, and tint from there that would be best for a match.
Old Jun 9, 2019 | 03:35 PM
Red86Z51's Avatar
Red86Z51
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
Are you just assuming that "L" means lacquer? Did you call your rep at S/W and ask him that question? My S/W people here in Indy are very knowledgeable and can answer ANY question you have about their product lines. That would be where I would go for the answer to that question.
Old Jun 12, 2019 | 12:59 PM
Double-O's Avatar
Double-O
Yes, the Sherwin Williams store manager said it was a lacquer code. Beyond that, he was clueless, and hasn't returned my call when he "would find out more", 2 days now. The old field rep is gone and waiting on a call back from the new one. (2 days also). My guess is S-W stores are independently owned explaining why you get good service.
May try my local Finishmaster jobber. I've worked with them in the past with good results.
Thanks for your suggestions.
Old Jun 12, 2019 | 03:37 PM
Red86Z51's Avatar
Red86Z51
Gotcha! And I just learned something new myself about the SW codes...so for that I say thank you! Sounds like you have a direction to go that may actually net you the end result you're going for. I have had had good luck with Finishmaster as well.
Best of luck!
Old Jun 16, 2019 | 03:26 PM
DUB's Avatar
DUB
I have found that in the paint system I use that many of the old colors have been converted so I can shoot BC/CC. For those that have not...I can normally find a color of a new car in my color chips that is so darn close it will pass or take minimal tinting to get it to the color where no one would know the difference.
Keep in mind that every color has a the 'standard' that the manufacturer wanted it to be painted. But there is no way in heck that when the color is being shot at different locations...and on different days that the color is PERFECT as the standard that was approved. THUS...we have what we call 'variants'. This is NOT my opinion...but a FACT.
Reason I know this to be true because my color decks have actual sprayed out color chips of the actual color and ALL of the variants that meet the criteria to become a paint variant chip.
DUB
Old Jun 17, 2019 | 12:39 AM
Double-O's Avatar
Double-O
DUB, thanks for the words of experience.
I went ahead last week and mixed a couple of ounces starting with a color chip formula from a Prospector deck system. Came out close enough for touch up but my Ontario Orange color is Firemist and looks slightly iridescent. Finishmaster has a formula for Xalta waterborne and Nason solvent. Going to check that out. Still waiting to hear back from S-W
Another question is what is your opinion of the color matching cameras?
Old Nov 3, 2019 | 09:15 AM
firstgenaddict's Avatar
firstgenaddict
BASF bought the company which manufactured the FIREMIST pigments. They are currently available from BASF.
To Modern Paint Formulas for Old Codes
