Body cart
From Alan 71'
https://www.corvetteforum.com/forums...rchid=77456658
Scroll these links.
Remove the distributor for clearance issues.
Attach your rear straps by the #3 body bolt and attach the front straps just in front of the forward door seam. Keep the radiator bracket in place for stability, if it's removed run a strap back to the windshield frame just to keep the nose up.
Make sure all frame ground connections are removed there are 7 or 9 I believe. Make sure all frame to body connections are disconnected.
As you lift, do it slowly (you may here a pop which is just the body frame having been together so long, unless of course you forgot something) making sure it is completely balanced/level.
Over inflate the tires as the frame will roll easier.
Have the dolly inline and ready to roll under the body.
Take your time, think it through and all will go well.
From Alan 71'
Scroll these links.
