Paint/Body Corvette Materials, Techniques, and How To
C2 sealer
Old Oct 26, 2023 | 10:57 AM
dafloi001's Avatar
dafloi001
Default C2 sealer
Thanks in advance for any help with my situation. I have a c2 coupe that has areas of bare fiberglass showing to the point that you can feel the strands of fiberglass how can I seal that so I can continue with any body work.
Old Oct 27, 2023 | 09:28 PM
jwindarwin's Avatar
jwindarwin
I would apply 2 or 3 coats of fiberglass gel coat. After that sets up I would sand it smooth with 80 grit.
Over that I apply epoxy primer then a couple sessions of high built 2k primer sanded to perhaps 400 grit, then topcoat to proper color.
Old Oct 28, 2023 | 07:37 PM
Joe C's Avatar
Joe C
i had a similar situation with my 69 coupe that i stripped to bare "glass." applied a TWO PART EPOXY PRIMER followed by a couple coats of a primer-surfacer, sealer and topcoat. i sold the car after 9 years, and saw the car 10 years later, and the paint still looked good.
Old Oct 29, 2023 | 10:20 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
PPG, Inds., major supplier of auto paints, has an excellent help line. Give 'em a call.
https://www.ppgpaints.com/contact
Old Oct 30, 2023 | 10:23 PM
csherman's Avatar
csherman
2026 Corvette of the Year Winner - Unmodified
2025 C1 of the Year - Unmodified Winner
2019 C1 of Year Finalist (stock)
2018 C1 of Year Finalist
Do ALL your body work to bare fiberglass
You WANT that filler or repair to bite into bare glass
I DO NOT use Gel Coat - In my opinion it is OLD technology
Alot of guys use it - I dont in my shop
We feel there are way better products and new products
After body work we have a process of primers
- Epoxy over your body work
- Then a 2k polyester or 2k primer
- You may put down several rounds of primer
- Sealer before paint
Chris
TiN Restorations
Plano IL
To C2 sealer
