Paint/Body Corvette Materials, Techniques, and How To
Vette Panel Adhesive availability
Old Aug 2, 2024 | 04:27 PM
Con's Avatar
Con
Default Vette Panel Adhesive availability
Anyone have any luck buying a quart of Evercoat 870 that's still within a year of manufacture? I'm striking out. Tried our local National Coatings and I had to educate them about shelf life and how to read the date code. Sherwin Williams hasn't sold any locally in 5 years and they checked all stores within 500 miles. I'll try O'Reilly's next but don't hold out much hope.
I'm learning to do fiberglass repair, and repairing some old very poor work on my transmission tunnel. Using Dub's tutorial. He was a huge advocate of VPA.
Appreciate any advice.
Old Aug 2, 2024 | 06:19 PM
kanvasman's Avatar
kanvasman
I love the stuff too. My O'Riellys has it here in SC but I did a search and Eastwood has it. https://www.eastwood.com/evercoat-ve...rt-100870.html
Old Aug 2, 2024 | 07:53 PM
Con's Avatar
Con
Thank you. I'll try them. Still waiting for Summit too.
Old Aug 3, 2024 | 02:11 AM
speedracist's Avatar
speedracist
I just got a quart from Eastwood. Can you tell me how to read the date code?
Old Aug 3, 2024 | 06:57 AM
Con's Avatar
Con
If it's 6 digits the first 3 are year month (YMM). the last 3 are meaningless to us. So 310_ _ _ would mean 2023 Oct and expires Oct 2024. They changed to 7 digits in late 2023.
If it's 7 digits the first 4 are YYMM and last 3 don't matter. So 2401 would mean 2024 Jan, expires Jan 2025.
I got this from Evercoat customer service.
Old Aug 3, 2024 | 10:54 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Are you sure the 1 year shelf life isn't referring to an opened container? Have you contacted Evercoat about shelf life of unopened product?
Old Aug 3, 2024 | 08:10 PM
Con's Avatar
Con
When I called to understand the date codes, customer service said the VPA expired one year after the date on the bottom of the can. Probably worth another call to see if I get the same answer a second time.
There's also another thread here where someone said he tried to use an expired product and it was a disaster.
Old Aug 4, 2024 | 02:15 AM
speedracist
My can I just got from Eastwood is numbered 2403330, so apparenty only 4 months old. Thanks for the info.
Old Sep 16, 2024 | 12:13 AM
20mercury's Avatar
20mercury
Default I order from Summit and always plenty within exp date
After trying a few diferent sources, i now always order from Summit and when received plenty before expiration date. VPA is getting more expensive all the time along with everything else.
I always store inside to avoid temp extremes. When I first open a can I stir for 3 or 4 min, a workout, to make it is well mixed before use
Old Sep 16, 2024 | 08:21 AM
Con's Avatar
Con
Thanks for the info. Both Eastwood and Summit are the go-to places. They actually understand the product.
To Vette Panel Adhesive availability
