line locks
Not having to bend or flare brake lines and having them the correct length, and made of to OEM standards is worth the savings in hassle you will realize when you go to install your line lock.
It is engaged by pressing and holding the brake pedal. Then pushing and holding the line lock button. Releasing the brake pedal while still holding the button. Now the front brakes are engaged but not the rears. Now if you at this point get on the gas, while holding the button, the rear wheels will spin and smoke up/heat up/ become sticky if you are running soft compound tires.
Release the button and the car will roll ahead normally but with hotter, stickier rear tires. This of course helps to improve traction.
It's pretty easy to do a burnout w/o the line lock, but I will say that it probably does save you some rear brake pad wear...
Ron
Ron
and thats why I went with a line lock. Your rear brake pads are going to wear a bit more if you do burnouts w/o the line lock.
The rear gears are whining way above what is normal, due to damage incurred while doing burnouts w/o a line lock. This, per DTE appraisal of damage. Now I have to buy ANOTHER stg. 2, 3:73 diff. and line lock, just to get rid of what is the loudest whining I have ever heard from a C5 differential! Take heed!!!
From our experience in building over 500 of these units to date, the greatest cause of differential clutch pack failure is due to the extreme overheating of the sintered bronze clutch discs within the clutch pack assy. while doing an aggressive water-box burnout (or any type of burnout for that matter) while the brakes are applied.
Often times, the rear brakes do not apply the same holding force from side-to-side when applied in a burnout scenario, which causes one wheel to spin at a faster rate than the other; therefore forcing the differentiating assy./clutch pack/spider gear assy. to operate at elevated torsional loads due to the excessive wheel-to-wheel speed differentiation.
Excessive, uncontrolled heat rapidly ensues within the clutch pack assy. which not only cokes/burns the lubricant almost immediately, but partially welds/seers the clutch pack discs together. All of the additional metal particulate from this severe overheating/wearing event has to go somewhere, so the now-burned lubricant carries it throughout the differential assy- plugging the oiling passages, severely damaging the bearings, races, internal differentiating assy. and ultimately the gear set. Once the lubricant is coked/burned, it effectively loses its ability to provide proper lubricity properties, cleaning effects and of course, cooling ability.
This very reason is why we STRONGLY recommend high performance synthetic lubricants for ALL those who do *any* type of racing, as the O.E. lubricant absolutely does NOT have the ability to withstand elevated differential temperatures typically encountered with racing use...period. It's bad enough that these units barely hold enough lubricant in the sump to do its job, let alone partially handicapping it even further by using poor O.E. lubricant that was never intended to be used in this manner.
We've seen this type of differential failure all too often manyyyyyy times before....
Best Regards,
DTE
