Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
First Dyno runs, your thoughts?
Old Mar 20, 2005 | 07:11 PM
Pontiaker's Avatar
Pontiaker
Default First Dyno runs, your thoughts?
98 A4 with fresh air intake, Corsa cat back, LS6 intake manifold, 3.42 gears and a Vig 2800 stall. Ran 12.71 at 107.50 with a 1.78 sixty before the LS6 intake. I dont have any other dyno runs to compare this with, whatcha think?
Max power 300.56
Tq 301.90
Conditions, 65.57 deg F, 29.78 in Hg 45% humidity
Matt
Old Mar 20, 2005 | 08:20 PM
Face's Avatar
Face
Tq seems a little low. Probably would be a good idea to get a dyno tune.
Old Mar 21, 2005 | 10:06 AM
JoshVette's Avatar
JoshVette
get a good tune, I dyno'd my stock 02 coupe, came out at 308.6RWHP and 321.1RWT.
Old Mar 21, 2005 | 09:12 PM
Ebein's Avatar
Ebein
Max power 300.56
Tq 301.90
Matt
Definately need a good tune, I just have intake/exhaust and put down
322/340 in my 01 coupe
Old Mar 21, 2005 | 09:38 PM
Face's Avatar
Face
He has a A4, he'll dyno less than you.
Old Mar 21, 2005 | 09:45 PM
Pontiaker's Avatar
Pontiaker
I also thought it was a little low, this was done at a local show/meet and the shop that did it was used to doing alot of rice. Can the calibration of the machine(Dynojet) be off, they couldnt print me a graph that I could read.....The graphs are kind of screwed up, only really got the numbers.They kept losing the tach signal during the runs too.I really did it just for fun, when I get down to tuning the car it probably wont be there.Thanks for the input.
Old Mar 21, 2005 | 11:25 PM
Ebein's Avatar
Ebein
I'd Expect less but not that much less.
Old Mar 21, 2005 | 11:36 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Your rwhp should be around 310/315rwtq! I had a similiar set up with the PT-2400.
Old Mar 22, 2005 | 05:21 AM
vettenuts's Avatar
vettenuts
Was it done locked or unlocked? Which gear? Some run the auto's in 2nd gear. I don't think the numbers are low at all, especially if the converter wasn't locked. It is reflected in your 1/4 mile time so don't get too hung up on the dyno numbers.
Old Mar 22, 2005 | 06:13 AM
Mitch C's Avatar
Mitch C
When I had similar mods my 98 also dynoed 301 RWHP.
Old Mar 22, 2005 | 09:58 PM
VLVETTE's Avatar
VLVETTE
2004 A4 before(stock/w 2.73s) after 3.42s, Vararam, LS1 edit dyno tuned. Stock I was at 309 RWHP/329 RWTQ. You need a tune
Old Mar 23, 2005 | 11:30 AM
Pontiaker's Avatar
Pontiaker
Cool! So you guys that have replied so far, what's your best ET at the track?
Thanks!
Matt
Old Mar 26, 2005 | 07:41 PM
Rays Vet's Avatar
Rays Vet
Thanks!
Matt
Your numbers sound normal to me. 12.53 so far.
Old Mar 30, 2005 | 12:26 AM
Pontiaker's Avatar
Pontiaker
Iam doing 12.710 at 107 on a 1.78 sixty without your longtubes or cam with 300 to the rear wheels? Where's the rest of you guys, you run the rollers but not at the track?
Matt
Old Mar 30, 2005 | 05:18 AM
vettenuts's Avatar
vettenuts
Your tune shows over 13:1 on the dyno which likely puts you close to 14:1 on the street. Aren't you nervous about running that lean? Personally, I would rather a little lower peak HP and a more conservative tune.
To First Dyno runs, your thoughts?
