Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
I am Back
Old Aug 3, 2005 | 07:58 PM
kwikfix91's Avatar
kwikfix91
Originally Posted by ZR1Brian
Paul,
You were like a lost baby without your bottles. I'm glad the Doctor's let you have your bottles back.
Brian
200 and work it up
Old Aug 4, 2005 | 02:19 PM
Dave_Busch's Avatar
Dave_Busch
Great to see you back.
Old Aug 4, 2005 | 02:38 PM
tekhombre's Avatar
tekhombre
Originally Posted by Major Spray
Thanks to the commitment of a great bunch of guys The Vette Doctors.
My car finally hit the track and things are certainly going in the right direction. For everyone that is not familiar with the current mods. Here they are: The 4l60 has been replaced with turbo 400 in its stock location. The rear end was modified to act like a spool. A custom DTE brace was installed. My power plant is an ls2 block, C5R heads and a custom sheet metal manifold controlled by an Accel/DFI system. My power adder is a two stage Speed Tech Direct port nitrous system. All these changes at one time created one hell of a mission; we were plagued with many problems that needed to be worked out.
Now the results: Two 10.1 passes followed up with two 10.0 runs all N/A going thru the traps at only 3500 rpm. The motor ran flawless. The tranny worked perfectly (after being in and out at least 6 times) The convertor was way two loose flashing to almost 6,000 N/A ( that will be getting swapped out this week) The rear even stayed in one piece after some nice launches off the brake.
This car will have no problem running mid nines@ 3400lbs on motor with right gears and convertor.
Now for the best part!
The Doctors said that if I made thru the day with out braking. I could have my Bottles Back
I'm glad you are back Paul, it would be nice to have some LSX competition.
Julio
Old Aug 4, 2005 | 02:50 PM
tekhombre's Avatar
tekhombre
Originally Posted by DOUG @ ECS
Actually Alex holds the title for quickest n/a C5 in Mikes car.
Mario's 447 holds the title for fastest n/a C5
Kidding aside, glad to see your back in action
Let's re state this,
Mike, I mean Alex holds the quickest and fastest na C5 with gasoline.
Mario's 447 holds the title for the fastest na C5 with gasoline and methanol.
Old Aug 4, 2005 | 02:53 PM
tekhombre's Avatar
tekhombre
Julio
Old Aug 4, 2005 | 03:01 PM
tekhombre's Avatar
tekhombre
Old Aug 5, 2005 | 01:15 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Mario's car run on 100% gasoline, so once again it holds the title for fastest na C5. Not to worry Julio you still have the quickest, converted to an auto, C5 in all the land.
Of course in reality, who cares about either one.
Old Aug 5, 2005 | 02:31 PM
Major Spray's Avatar
Major Spray
I had the quickest, converted to an auto, C5 in all the land. Ups mine had a power adder I am out
Old Aug 5, 2005 | 02:33 PM
DOUG @ ECS's Avatar
DOUG @ ECS
They are all very impressive
Old Aug 10, 2005 | 09:58 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Good job on getting the Nitrous this weekend too!!
Old Aug 10, 2005 | 10:37 AM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
WB! Starting @ a 200 shot DAMN!!! Love the vids I have seen of you and your car too. Thanks!
Dave
Old Aug 10, 2005 | 03:06 PM
Anonymous 1's Avatar
Anonymous 1
Major, welcome back.
The car looks great, just paint the hood, add the stripe and if it goes as good as it looks it should really hustle.
I hope the T400 set up ends up working out for you.
best of luck.
Old Aug 10, 2005 | 04:47 PM
  #33
robz's Avatar
robz
best of luck.
Paul, for now your name is just "Major" until you start spraying it.
Good to see you and Bill back.
Old Aug 23, 2005 | 10:23 AM
  #34
Gus's Avatar
Gus
Cruise-In III Veteran
Paul
Any new #s Can't wait to see you put this thing deep in the 8'S
Old Aug 23, 2005 | 05:23 PM
  #35
vetred's Avatar
vetred
This is why I NEVER visit this thread , now I'll be sleeping with the lights on for a week
Old Aug 29, 2005 | 07:43 PM
  #36
hubes's Avatar
hubes
I havent checked for a while, last i heard you had a c5r block, whats the displacement on the new setup? and are you still running IRS?
