Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
What will this set up get ???
Old Sep 18, 2005 | 04:32 PM
UpToVT's Avatar
UpToVT
Default What will this set up get ???
I have a 1999 C5 M6 with...... Vararam, Kooks Headers, Hi Flwo Cats, X pipe, Borla Stingers, Short Throw Shifter, 3.90's on Toyo T1's....
I dynoed Without Vararam at around 340-345 rwhp/torque.....
What will I do in the quater from best to average.......
And with DR's.....
Old Sep 18, 2005 | 08:49 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Low 12s. Depends on air temp as well and traction. 11.94 is my best and my setup is similar to yours. I consistantly run in the upper 11.90s. I also use ET Streets, have 4.10s, VaraRam, LGM LTs and Stingers.
Old Sep 18, 2005 | 09:34 PM
Mitch C's Avatar
Mitch C
On average you should run low 12s. In cool perfect weather you should dip into the 11.9s if you are a good driver.
Old Sep 18, 2005 | 10:57 PM
UpToVT's Avatar
UpToVT
What is the conversion on Vettes on the 60 foot times...... What could a good 60 foot times with street tires (Toyo TS1). And if possible at what RPM should I be launching at...... Any tips would help me beat my friends in there Turbo'd up 4 bangers.
Dont want to be spanked...... Thanks
To What will this set up get ???
