Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
DRM tuned C5 thats sick!
Old Oct 4, 2005 | 10:56 AM
95BlueBomber's Avatar
95BlueBomber
Default DRM tuned C5 thats sick!
So I have a 98 DRM C5RS, supposed to be one of the better tuners but my results aren't showing this. Not to bash DRM but with the money I have in this car it should perform a lot better than it does. I see people with heads and a cam putting down 400RWHP all the time. I have 2.02 valve heads, custom grind cam, long tube headers, donaldson blackwing, B&B exhaust, and a Z06 intake. I put down 356RWHP. I am running stock injectors and heard this could be the problem. Does anyone have a solution to my 400 horse woes?
Old Oct 4, 2005 | 11:39 AM
Tru_Ice's Avatar
Tru_Ice
Yup that's a bad tune, w/ just a bad tune our cars can drop 40-50rwhp. Fix the tune and I'm sure you'll be alright.
Old Oct 4, 2005 | 11:43 AM
marco383's Avatar
marco383
I have to agree; your numbers are way off. I've seen head/cam/bolt-on C5s make 500 RWHP, and there have been a plethora of them over 450. You need a knowledgable shop to do a diagnosis of all the mechanical and electrical bits that can cause an engine to underperform.
Old Oct 4, 2005 | 01:19 PM
JR_VET's Avatar
JR_VET
Want To Have 400rwhp
What gears are in the rear and what Tranny are you running? Also who did your tune? Because I agree with what you have you should be laying down atleast 400. retune the auto
Old Oct 4, 2005 | 02:13 PM
95BlueBomber
Default More Spec's....
My car is an automatic, 3.15 gears. Gears shouldn't affect the hp rating should it?
Old Oct 4, 2005 | 05:06 PM
Face's Avatar
Face
Yes the gear ratio can affect dyno numbers, but not a large amount though, depending on what ratio you go with.
What grind on the cam?
Do you have a high stall converter?
If it's a small cam, your numbers may not be off by much.
Old Oct 4, 2005 | 05:13 PM
Mirek's Avatar
Mirek
What is a 2.02 head exactly ? What are the cam specs ? Who assembled it ? Is the cam degreed ? How thick are the head gaskets ? Which headers ? How much timing....?
Alot of missing details come into play. Having an auto will always hurt.
Old Oct 4, 2005 | 05:27 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
With an A4 it is not a given. Many called when the first 400rwhp H&C came out so if the H&C is an old design it may not have the power.
Old Oct 5, 2005 | 01:14 PM
CarsRFun's Avatar
CarsRFun
2.02 are the valve sizes in the heads.
Old Oct 5, 2005 | 03:06 PM
JR_VET's Avatar
JR_VET
In the days world how can you get bad Heads and Cam the only way you car doesn't push HP is because something is wrong. Now when you say you have 2.02 heads are they stock GM heads or are they after market. Are they ported polished and what is the flow are they decked what size gasket did you install the heads with. does the cam match the flow of the heads? are they after market or were they stock? did you place a thick gasket on the heads a decreased the compression ratio. see there are so many question and you haven't provided any answer.
Old Oct 5, 2005 | 04:12 PM
Mirek's Avatar
Mirek
Compression ?
All we know is you have some sort of a cam and some kind of headers. I'd say 356 is about right with an auto......
Old Oct 5, 2005 | 04:46 PM
C5XTASY's Avatar
C5XTASY
BTW, stock injectors for a 1998 were 28.8 lbs., way more than enough for well over 400 rear-wheel horsepower. What did you spec the car out to? What did you ask to have installed? A cam is not just a cam, heads are not just heads and headers are not just headers. In other words they're not all the same. What you end up with is the result of a combination of the parts you have installed. Talk to Doug, Randy or Tim. They are all great guys who will gladly work with you. Rippie Motorsports is top-notch. I know from experience.
Ed
Old Oct 5, 2005 | 04:53 PM
C5XTASY's Avatar
C5XTASY
BTW, how long have you owned your car?
Ed
Old Oct 5, 2005 | 08:04 PM
JR_VET's Avatar
JR_VET
Ed
Talk to some guys who have been there and give then your specs. and see what they say.
Old Oct 6, 2005 | 11:34 AM
vetpet's Avatar
vetpet
Default In the same boat.
I'm having the same issue. With LS6 ported heads, 2.02 valves, LT headers, hi-flow cats, X-pipe, Z06 rear exhaust, Comp Cams 212/218 (I know it's a small cam but there's a story behind it) I made 336rwhp before tuning and 348rwhp after tuning. My car is a 2001 so it has the LS6 intake on it already and I used a Z06 airbox. I'm also being told it's the tune and am waiting to go back again. At the track the car went 113mph on the stock runflats (2.2 60') with a best ET of 12.88. Funny thing is all the HP calculators say that 113mph = 385rwhp (447hp at the flywheel) so I'm not sure if dyno numbers can be believed. Dyno's are good for tuning (somewhat) but being able to log live data while driving is the best way to get your car tuned properly. The shop I went to tuned my car in an hour but I don't think that's enough time. After the tune I believe you should drive the car for a while to allow the PCM to go through a relearn and then go back and look at the data again. This will give you a chance to make more finite adjustments and should get you better performance. I know guys say that experienced tuners can get it right in an hour or so but I'd still want to go back and see if things have changed from the original tune. That should be included in the tuning.
Old Oct 6, 2005 | 02:54 PM
Face's Avatar
Face
A4 or MN6? Stock rear?
Old Oct 6, 2005 | 07:27 PM
vetpet's Avatar
vetpet
I have an MN6 with the stock 3.42 gears.
To DRM tuned C5 thats sick!
Old Oct 7, 2005 | 12:02 AM
C5XTASY's Avatar
C5XTASY
I suspect that you are not putting down the 385 rwhp you think you are, and the dyno number is about right. Stock 2002-2004 Z06s get 345-350 rwhp and they run in the low 12s. I realize they are geared a little lower, but not half-a-second worth. Getting your tune re-checked should be interesting. Good luck!
Ed
Old Oct 7, 2005 | 12:11 AM
C5XTASY's Avatar
C5XTASY
Very strange. The initiator does not reply back with any answers, even though he's made other posts, to other threads in the Forum, since he's posted to this thread. He has not contacted Rippie Motorsports. Don't quite understand his reasoning behind starting this thread if he doesn't plan on providing any feedback.
Ed
Old Oct 7, 2005 | 01:23 AM
PHPD7102's Avatar
PHPD7102
St. Jude Donor '14-'15-'16
My car has the bigger intake and exhaust valves as well and is a MN6 vs your A4 but my numbers are closer to what you should be. Which intake are you using, if its still the LS1 there is part of your problem.
