Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Valve float/valve harmonics
Old Oct 8, 2005 | 02:38 PM
vettenuts's Avatar
vettenuts
Default Valve float/valve harmonics
Does anyone have a dyno curve they can post that has "confirmed" valve float or valve control issues? I am looking for a curve that had the problem and then was fixed and how.
Old Oct 8, 2005 | 04:43 PM
bluewire's Avatar
bluewire
Active Streak: 90 Days
I suggest doing a search over at ls1tceh.com. I just saw a graph someone posted with some bad valve float and was recently.
Old Oct 8, 2005 | 05:40 PM
vettenuts's Avatar
vettenuts
Tried that, but many are later found to be other problems. Everything I read says valve float will make some noise when it happens. Trying to confirm the symptoms on a dyno sheet and to the ear.
Old Oct 9, 2005 | 01:33 PM
korvetkeith's Avatar
korvetkeith
I've only known valve float to be associated with high rpm power falling off and broken parts. Get and set of Comp 918s and rev that biotch!
To Valve float/valve harmonics
