Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
1/4 mile advice needed
Old Oct 13, 2005 | 11:18 PM
Fujikura's Avatar
Fujikura
Default 1/4 mile advice needed
Ok, here's the situation I just bought BFGoodrich G-force T/A Drag radials. I was wondering what PSI I should run it at...it says 44 PSI On the tire, but that's wayy too high...I think, right? I was thinking running them at 25...The elevation out here is 2700 ft... I also would like to know if I should burn out in or out of water, I've been told to do one and the other by different people. I also wanted to know what I should rev to before launching Im on an Automatic and I dont have a Torque converter, Just a VARAM and Exhaust thanks for all the help to come, I also launch it in 3rd, correct??
Old Oct 14, 2005 | 12:37 AM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Can't help w/ the auto launch, although I'd think launch it as high as the converter will allow, but I may be wrong. Otherwise, start at like 1500 & go up from there, depending on what the track & it's prep will allow.
As far as the drag radials, roll slowly thru the water, then pull up a few feet past it. Then do your nice, smokey DR burnout.
NEVER EVER do a burnout IN the water. You'll throw water everywhere & when you get to the line, you'll sit & spin.
I'd also lower the psi down to 16 or 17 & adjust up from there.
The psi on the tire is usually the max psi allowed for the tire.
Hope this helps!
Ron
Old Oct 14, 2005 | 09:40 AM
chaase's Avatar
chaase
St. Jude Donor '12
Definitely do the burn out and drop the tire pressure to 16-17psi (you can start a little higher if you like, but 25 is way too high).
As for launching the auto, get the RPM's up as high as possible and then floor it on the third yellow.
Having a higher stall converter will help a lot, as you can launch at higher RPM.
And yes, it is correct to launch in 3rd
Chris
Old Oct 14, 2005 | 10:35 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
W/o a converter if you launch well a 1.91 60' would be good...........
I would do the burnout with T/C off, stage, put it in 3rd, bring the revs up to load the driveline and then back to no more than 1K rpms.......WOT on green
What size Dr did you buy?
Old Oct 14, 2005 | 12:29 PM
DragMan's Avatar
DragMan
Id say 16 to 20 lbs hot!
Old Oct 14, 2005 | 03:16 PM
Fujikura's Avatar
Fujikura
I went with the 275/35 18's They didnt have 275/40's so I went with those, thanks for all your help
Old Oct 14, 2005 | 07:46 PM
vettorviper's Avatar
vettorviper
Cruising
Default new guy needs advice
I CANT GET MY CAR TO DO A BURN OUT EVEN WHEN I TURN OFF THE TRACTION CONTROL. DO YOU HAVE TO BE 3RD TO DO THIS OR WHAT.
Old Oct 14, 2005 | 10:44 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Fujikura, you have some good advice already. Only other thing I would recommend is checking out the Corvette Challenge at LACR as that will give you exposure to other Corvette drivers in your area
www.corvette-challenge.com
Old Oct 15, 2005 | 01:20 AM
Fujikura's Avatar
Fujikura
Oh that is so awesome I'm so there!
Old Oct 15, 2005 | 07:57 AM
Cruise-In V Veteran
NCM Ambassador
And with these being 25.6" dia..........a little smaller than stock that makes your rear gear like a 3.30 I use the same tire on our vert.
Get a converter & launch like this
Old Oct 15, 2005 | 09:47 PM
Blue85L98's Avatar
Blue85L98
Cruise-In III Veteran
I don't want to hijack your thread...the next West Coast Corvette Challenge event at LACR is October 29th. Check out our website at:
http://www.corvette-challenge.com/
and the thread in the drag racing section is at :
http://forums.corvetteforum.com/show...90&forum_id=90
-dave
Old Oct 16, 2005 | 12:28 PM
Dr.Ron's Avatar
Dr.Ron
If you're new at burnouts, use 1st gear. It easier to get the tires going. After some practice, use 2nd gear, as 2nd allows you to spin the tires faster, thus, heating them more.
In either gear, just bring the revs up to 5300, dump the clutch & quickly get on the brakes, but only enough to hold the car from moving...You'll move froward a few feet until you hit the brakes, but don't panic.
Ron
Old Oct 18, 2005 | 03:13 PM
vettorviper
Cruising
i have an automatic. what do you suggest for it. thanks for you help.
Old Oct 18, 2005 | 07:16 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
TRACTION CONTROL OFF.... Pump the brakes, hold the brake pedal down. In third gear step on the gas, and ease up on the brake pressure, you should now be smoking the tires. You can lightly touch the brake in order to keep the car where you want it. Now completely remove your foot from the brake and roll out of the burnout.
To 1/4 mile advice needed
