Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
New Best
Old Oct 25, 2005 | 07:23 PM
TLKSCHP's Avatar
TLKSCHP
Default New Best
Went to the track Sunday due to some LS1 bashing by some Mustang guys. After i made my first pass the only ones wanting to play were the ones with heads, cam and NOS. Ran a 12.34@111 w/ 60ft 1.78. problem was I couldn't back it up, that bugs me. Every pass after was 12.5X with the same MPH and 60 ft, why? The only thing I can figure was that I just drove 40min at 70mph on the Highway before pulling in the track and that set the pcm up different. I have full bolt on's with a pt2400 stall and 3.73's. I have a Blackwing now but should have a Vararam really soon. The week before I was running 12.7X all day, we had some good air this week and made a big difference except I was going into a 15MPH head wind. Difference in DA was 2230
Best Vid for the day The other car is my freind Matt running a yank 4000 and a futral F13 cam w/2.73 gears
Right Click & save
Old Oct 25, 2005 | 10:43 PM
sixspdvet's Avatar
sixspdvet
Congrats on the new times... How long did you wait before running the first round?? and what was the water and oil temps??
I think if you ran a 12 3 or 4 then ran 12,5's could of been the car was hot. But still you did good....
Ernie
Old Oct 26, 2005 | 01:32 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Congrats!
Old Oct 26, 2005 | 06:07 AM
Tino's Avatar
Tino
My experience at the track with my nearly stock 04 is that the first pass is your best and once the motor gets heat sink, the subsequent passes are slower.
Tino
Old Oct 26, 2005 | 10:57 AM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Tino
When I've run 1-3 passes in succession, each ET was lower then the previous. These cars like some heat.
Heat soak will result after many hot laps...Not good for the trans & clutch either.
Ron
Old Oct 26, 2005 | 05:10 PM
TLKSCHP's Avatar
TLKSCHP
The car sat plenty before each round, maybe I let it get to cold. Plus the outside temp was 52, car was running around 180 across the board when I got their. Probably won't get another day with good air around here for while, so back to the high 12's low 13's
Old Oct 27, 2005 | 09:51 PM
JimK-98's Avatar
JimK-98
My first pass directly after getting to the track is always the best also on my '02
Old Oct 27, 2005 | 11:24 PM
vetterlatethannever's Avatar
vetterlatethannever
Congrats on the new best!!
To New Best
