ok here goes. My 99 C5 has over 100 thousand miles. I bought a TT kit for it and I am thinking of just throwing it on the stock block as is with some fuel upgrades. My car has babied highway miles. Will I be able to pump about 550 to the wheels out of this highmile block for atleast some time if I don't get on it all the time? Basically I chose the twin turbos over heads and cam. Whats your opinion?
Hopefully you are asking this question, with your solution already identified. But here goes...
The kit that were trying to sell is way overkill for a stock block. I think the turbos were T4's or T6's. You will at least need to get the turbos sized more appropriately for the combination. Even then, its not a matter of will it blow, but when will it blow. Do it right forge the block. With the complexity of the kit that you have, you'll save on labor by doing the motor while everything is out and apart.
I am redoing the piping all together. Im just using the hot parts and rebuilding from there. But youre right I should do that. What all would I have to get to forge the internals on the block. Could I get away with forged pistons and rods?
Pistons, rods, rings, bolts, timing chain, and a good oil pump for the TT's.
Mark
Mark,
You are completely right (I'm rebuying all that stuff for the new combo...)... I kind of forgot about it all becuase is kind of assumed, especially if you have a high mileage block. These are things that people don't consider as they start to price things out, but the cost do add up as you start to consider those things.
IMO, if someone loses #7 piston, then I would say they leaned out too much on the top end. I have been following this issue on here, and that is what I am coming up with. Seems that some people doesn't have steady fuel pressure on the top. As the fuel pressure drops, the engine starts to lean.
I think a 100,000 mile motor would be more acceptable to detonation also due to oil blow by that can cause oil in the intake to get into the combustion chamfer to form carbon build-up and hot-spots. If you did do it, I would keep the boost at 5-6 psi MAX, and make sure you have good fuel supply, a good "safe" tune and decarb the motor.
I could see doing it with a 50k mile motor, but 100k miles? Whats the point of putting it all together then taking it all back apart a week later? It would save so much time and money to do it all upfront.
