Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
C5 Coupe vs. Ford Lightning
Old Feb 1, 2006 | 11:07 AM
litnrod's Avatar
litnrod
Default C5 Coupe vs. Ford Lightning
Who would win...???
99 C5 MN6, intake, exhaust mods only.
Lightning has about 410 -420 RP (Rodent Power) s/c and 3.73 gears...
From standing or rolling...any input.
Old Feb 1, 2006 | 01:08 PM
99SoCalFRC's Avatar
99SoCalFRC
To about 75 the vette will have a slight edge, after that the vette will walk it. Not that I have any experience.
Old Feb 1, 2006 | 02:42 PM
Dan SS2471's Avatar
Dan SS2471
Is that HP to the wheels or flywheel? My '01 with bolt-ons made 440/537 to the wheels and ran 12.3xx @ 110 in full trim on Nittos. If it's 420 to the crank, you're pretty well matched. If it's to the wheels, he may pull you. Remember..Lightnings are pretty easy to launch so watch it if you're going from a dig.
What kind of times does your car run?
Old Feb 2, 2006 | 07:40 PM
Tony Hughes's Avatar
Tony Hughes
5th Gear
Default Z-06
I got intpo it w/ a Lighting @ about 60 mph I shifted down to 4rth a walked off and left him.. I wasn't very impressed. I could have gone into 2nd. it was stock at the time '03.
Old Feb 2, 2006 | 08:13 PM
tlaselva's Avatar
tlaselva
HP to weight ratio would give you the nod.
But don't take the Lightning lightly. They can be suprisingly quick up to highway speeds being automatics and high torque numbers.
Their poor aerodynamics slow it down quickly after that.
Make sure you launch your car well, and shift properly. If you do, it should go down. Mess up the launch, and you'll likely be playing catch-up for most of the run.
Old Feb 4, 2006 | 10:04 AM
Pit Bull's Avatar
Pit Bull
Before I got my 01 ZO6, I had an 00 Lightning, bone stock it ran 13.86, doing nothing but lower the tailgate. It is amazing how easy it is to modify one. With a 4lb blower pulley, chip and mass air meter, I ran a 13.04 @105mph with a 1.91 60ft on the stock F1's. The truck is very easy to launch, foot brake to 900 rpms then mash the gas, very little tire spin.
Old Feb 4, 2006 | 06:53 PM
jcdurst1's Avatar
jcdurst1
3rd Gear
Default 550 HP lighting ower
I've raced a vetts with my Lighting! I've got a 15 pound Kenny bell supercharger and other bolt on and have dyno over 550 HP. I've never lost to a Vett but I have to admit I really had to lanuch just right to out run one. F150 Lightings must be respected..
Old Feb 4, 2006 | 08:05 PM
Mike04's Avatar
Mike04
My stock A4 was evenly matched with a Harley Davidson F150, which is very close to the lightning, at freeway+ speeds (closed coarse).
Old Feb 5, 2006 | 09:19 AM
SpeedyD's Avatar
SpeedyD
I haven't raced a lightning but I have seen a vid of a stock c5 zo6 racing the dodger ram srt, and that's putting out 550HP, (i think) the dodge did pretty good up until highway speeds and the vette started pulling! I'd say you got em!!
Old Feb 6, 2006 | 08:31 AM
6Speeder's Avatar
6Speeder
Actually the HD has less boost, less HP, and weighs about 500 pounds more than a Lightning.
If the Lightning is stock, the race is yours to lose.
If he has modded it (very easy to add 100 HP), good luck, you'll need it.
I drag race both, my Lightning is now about 1/10 of a sec quicker than my Vette.
Old Feb 6, 2006 | 09:35 AM
litnrod's Avatar
litnrod
thanks for info gentlemen,
I have a guy at work trying to talk some stuff. I just wanted a little info before I have to wax him.
I have yet to dyno...post some raw numbers on just intake and exhaust mods?
Old Feb 6, 2006 | 07:45 PM
2002 MATRIX SC's Avatar
2002 MATRIX SC
Iv'e seen a few lightnings run 10.8 at the track, modified of course.
Old Feb 6, 2006 | 08:06 PM
ls1vette97's Avatar
ls1vette97
I've never seen a bolt on lightning do better than mid 12's....
Old Feb 6, 2006 | 10:07 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Stock to stock, I think the L would take you off the line but the Vette would quickly catch up and take 'em out. L's run a little under 14 in the quarter bone stock. With about $1000 in mods they are a good ways into the 12s. My buddy I go to the track with has one (so I'm not pulling this out of my ****). He sold his Vette to get one. And it is possible to get high 11s with bolt ons.
Old Feb 18, 2006 | 05:38 PM
tlaselva's Avatar
tlaselva
Here's a vid of my stock '03 Z06 vs. my buddies modified Lightning, pulley, chip and full exhaust or at least the ones I know of.
Notice in the vid how the race changes once it gets up to highway speeds.
Save As. . .
Old Feb 19, 2006 | 09:02 AM
6Speeder's Avatar
6Speeder
SHOOT//// My Lightning, bolt on only, with stock: heads/block/cams/trans/convertor/etc. runs mid 12's AT 5,320 FEET ALTITUDE. Guys running at lower altitude with my mods are DEEP in the 11's.
Old Feb 20, 2006 | 02:29 AM
Splaterman's Avatar
Splaterman
those lightnings are quick, a buddy of mine goes 8.5 in the 1/4, but he does have a 400 shot and supporting mods on it
To C5 Coupe vs. Ford Lightning
Old Feb 20, 2006 | 07:00 PM
boostfedtruck's Avatar
boostfedtruck
i had a 01 stock lightning that was bone stock down to the f1's and my best was a 13.3, watch yourself from a stop but everything goes downhill for them from a roll
Old Mar 3, 2006 | 03:49 PM
6_speed's Avatar
6_speed
Cruising
Originally Posted by litnrod
Who would win...???
what are the lightnings mods?
Old Mar 4, 2006 | 01:27 AM
Cgillies86's Avatar
Cgillies86
I raced my buddy's lightning. We went from a dig, we were even through first(i got some bad wheel hop) but once i hit second I pulled him pretty bad. I had a vararam at the time, I think he had an intake and exhaust. In my opinion, you could take the lightning look at it this way:
Lightning:
power: 410 rwhp
weight: 4670 lbs
weight to power ratio: 11.39
Corvette:
power: with the mods you said I would guess you would have 320 rwhp +-10
weight: 3245 lbs
weight to power ratio: 10.14
Not to mention the corvette is a hell of alot more aerodynamic.
If you race him from a dig it will be a drivers race, but from a high speed roll you will walk the lightning.
