Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Dyno this weekend, quick question
Old May 11, 2006 | 10:59 PM
happa's Avatar
happa
Default Dyno this weekend, quick question
Im going to a dyno this Sat and going to see what she has to the ground. My question is what gear should I be in? I heard 4th. But want to make sure. Thanks for the help!
Old May 12, 2006 | 12:09 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
The dyno operator will likely take care of this for you, but just in case...
you should be in the gear with 1:1 ratio (3rd in A4; 4th in MN6)
TC/AH OFF
AC OFF
GL!
Old May 12, 2006 | 06:24 AM
vettenuts's Avatar
vettenuts
Make sure your air filter is clean, especially since we are in pollen season.
Old May 12, 2006 | 07:04 AM
zo6vetteman2003's Avatar
zo6vetteman2003
Would this be from experience??
Old May 12, 2006 | 12:10 PM
vettenuts's Avatar
vettenuts
Uhmm, um, err, well, maybe
Old May 12, 2006 | 12:32 PM
happa's Avatar
happa
Thanks everyone for the info!!!!!!
Old May 12, 2006 | 02:42 PM
Ranger's Avatar
Ranger
A couple other suggestions:
(1) Wear stock rear wheels/tires with the pressure at 30 psi cold
(2) When you start the pull make sure your coolant temp is 185-194. Higher than that and your PCM will pull power.
(3) Once you arrive at the facility cool the car down. If its hot when you dyno, hot cats will cause the Air/Fuel ratio quite rich as fuel is dumped to cool the cat. After the car is cool, then manage the coolant temp to the target in (3).
(4) Ensure the dyno operator gives you the graphs in SAE and with smoothing turned on.
(5) Ask the operator for the Excel version of the dyno graphs too; this produces rpm/rwhp/rwtq values in numerical form, which are handy for doing shift point conversions.
Ranger
Old May 19, 2006 | 12:36 AM
triblk6spd's Avatar
triblk6spd
chiming in here, what other forms can you get besids sae? one of my dyno sheets says std smoothing? how does this affect the numbers?
Old May 19, 2006 | 09:03 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
SAE and STD are correction factors that are applied to the measured results. STD typically results in higher numbers. This page explains it pretty well.
Old May 19, 2006 | 10:31 AM
zo6vetteman2003
STD numbers are what people who had disappointing SAE numbers quote they made.
"Was that on race fuel?" should be the next question lol!
Old May 19, 2006 | 02:40 PM
triblk6spd's Avatar
triblk6spd
got it. thanks.
To Dyno this weekend, quick question
