Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Cold Air Intake?!?!?
Old Feb 10, 2007 | 06:23 PM
spiral04's Avatar
spiral04
Originally Posted by Iron Maiden Fan
Before your do, you might want to try the "ice box" addition to your Blackwing. I did it to mine and all I can say is DAAAMMMN! Your already 3/4 the way, finish the deal with cold air. I've been running mine on my daily driver with no problems for over 2 years.
Use some "eyeball" sense. Look at the filter area of the Vararam and Callaway. The Blackwing has more filter area. When you add the cold air piece of the equasion, it's a no-brainer. Blackwing with cold air from beneath the radiator shroud beats 'em all.
http://www.teamzr1.com/Merchant2/mer...ct_Code=Icebox
sent you a pm
Old Feb 10, 2007 | 06:34 PM
Specter's Avatar
Specter
Originally Posted by SleeperC5
Halltech air bridge with a Blackwing air filter..works fine for me.
Is there a place where you can get just the airbridge? Is the airbridge worth changing for performance reasons?
Old Feb 10, 2007 | 09:01 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
Originally Posted by Deft
Yea, no flooded out parking lots either, is the filter much larger than stock in the Vararam?
Don't know, but I do know it supports the big HP.
Robert
Old Feb 11, 2007 | 04:28 AM
Iron Maiden Fan's Avatar
Iron Maiden Fan
I just saw a pic of the stock, honker and vararam filters and the vararam was actually smaller than stock! I'm thinking honker now, or blackwing.
The filter media in the Blackwing is bigger than Honker or Vararam. This translates to longer time between cleaning and less restriction.
Once you do the "ice box" mod, you have cold air too. That removes the advantage the Vararam and Honker had.
Any cold air intake will give a noticable SOTP increase. Go with what your comfortable with. I'm partial to what I chose because I looked long and hard at the available choices. I concluded that cold air with larger filter media was best. I've driven through torrential downpours and plenty of puddles with no problems.
These are just my thought process, and .02 worth, weigh your options and goals and get what you feel is best for your situation.
Old Feb 11, 2007 | 11:29 AM
Robert56@RNS
Collections Hold
I concur, if just a Sunday cruiser, then any will do. However, if your trying for every bit of ET, then the Vararam would be my choice.
Robert
Old Feb 14, 2007 | 09:00 PM
NOT2MELO's Avatar
NOT2MELO
Callaway Honker all the way, just looks so OEM and not cheap like some
of the others.
