hi everybody i have a02 z06 33000 mi dynatech lt headers high flow cats and x pipe also i did the ti ex mod and the flipe it mod to the air filter making it a bottom feeder with a k&n filter tb by pass and gm hot wires and tr55 plugs the bottom line is 381.54 max power and 372.52 max torque @82 degrees humidty 28% are these numbers low high or normal this is my first dyno i had it done at speed inc in schumburg il. any input would be great thanks much royski today she seems to pull much stronger thanks again
Seems a little on the high side, but if it was dont at Speed Inc. they have a dynojet which those dynos are always higher than Mustang Dynos....Are thos SAE numbers?
Just take it out to the track and see what it does out there.....dynos are to give you an idea what you have, and what you gained on upgrades.....the track numbers are the ones that matter
