Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
warning!!! possible dump post
Old Sep 13, 2007 | 02:01 PM
bm bradley's Avatar
bm bradley
Default warning!!! possible dump post
I've seen a few vids online stating the acetone will improve performance and gas millage. really wanted to try it, but sure am not willing to blow the motor on my car. do you guys have any input on this? here's a link I found on the subject:
http://www.pureenergysystems.com/new...00069_Acetone/
any one have any experience with this? -bmb
Old Sep 13, 2007 | 02:23 PM
utryd2's Avatar
utryd2
Old Sep 13, 2007 | 03:17 PM
bm bradley's Avatar
bm bradley
Originally Posted by utryd2
here's more http://peswiki.com/index.php/Directo..._Fuel_Additive this is very darn interesting to me
Old Sep 13, 2007 | 04:21 PM
Rag-Top Rick's Avatar
Rag-Top Rick
Why not play it SAFE and run Torco?
Old Sep 13, 2007 | 04:32 PM
Third Gear's Avatar
Third Gear
I've heard about this for years, but I've never had the ***** to try it yet... maybe I will.... Hmm... I might have to do my own research.
FWIW I've used FP60 for some time... however that's a fuel specific additive.
Old Sep 13, 2007 | 05:28 PM
bm bradley's Avatar
bm bradley
I posted 2 links to some info about it. I want to try it also
Old Sep 13, 2007 | 05:33 PM
bm bradley's Avatar
bm bradley
just went to the torco website, I wasn't able to find out what's in it. the acetone is much cheaper and possibly more efficient. what I read was the acetone help break the gasoline molecules down so that the gas burn cleaner and more efficiently. the MPG benefits are just that, added benefits. I've been reading lower emissions, better millage, more HP.
Old Sep 13, 2007 | 07:40 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
Very, interesting read, would love to run into someone that has and still uses it.
Old Sep 13, 2007 | 09:35 PM
bm bradley's Avatar
bm bradley
me too. that's why the post
Old Sep 13, 2007 | 11:41 PM
Third Gear's Avatar
Third Gear
I did a search, and found that in an episode of "Myth Busters" they tested the Acetone Myth and found that it actually had a negative effect on Gas mileage. Not to mention some reports of fuel system corrosion....
Hmm... I guess search is our friend.
Torco, FP60, Techron.... I guess I'll stick to those.
Old Sep 14, 2007 | 06:07 AM
vettenuts's Avatar
vettenuts
FP60 here as well. Had the intake off earlier this summer, the back of the intake valves were spotless. Heads are coming off over the winter, that will be interesting to see what affect it has on the piston carbon and in the heads.
Old Sep 14, 2007 | 07:35 AM
Fartpipe's Avatar
Fartpipe
OK my friend works for Stewart Warner Performance as a engineer. They decided to monitor this on 2 cars. One a turbo car and the other a 4cyl NA car both stick. Monitor the fuel economy doing the same drive each day to and from work shifting at the same RPM. Basically keeping things as identical as they could. Found a approx increase in theoretical fuel economy from one week to the next at .18 MPG increase. Now the BEST PART!!!!! After going into this further and doing some testing that you can do in your own garage. Take some acetone put some in a container and put a piece of rubber in the container with it. Measure the size of the rubber before and after. You will not like what it will do to your gas tank/lines,injectors etc.
Old Sep 14, 2007 | 02:07 PM
Third Gear's Avatar
Third Gear
Yeah FP60 is good stuff. When I use up the jug I have, I think I'm going to try their new FP Plus which is suppose to be even better.
Old Sep 15, 2007 | 12:29 PM
Phil97SVT's Avatar
Phil97SVT
I've ran acetone, xlyene and toulene in my corvette, all are good products.
Old Sep 15, 2007 | 12:48 PM
bm bradley's Avatar
bm bradley
why did you stop? did you get better mileage? what issues did you have?
Old Sep 16, 2007 | 09:20 PM
02milleniumrag's Avatar
02milleniumrag
I use a bio-based additive from rli.(am i allowed to say that?)
To warning!!! possible dump post
