Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Dyno before Header install
Old Oct 24, 2007 | 09:42 PM
LTCHAPPA's Avatar
LTCHAPPA
Default Dyno before Header install
2003 Vert. 6speed Corsa catback,blackwing,tune 330rwhp at present.Will be adding Kooks Long tubes and tune.Hope to gain 20-25HP.Is this realistic?
Old Oct 28, 2007 | 07:13 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You should be right about 350+ RWHP and 340+ RWTQ after your done!
This is becasue of what my buddies Vette did with the similar set-up!
Thanks,Matt
Old Oct 28, 2007 | 07:23 PM
vettenuts's Avatar
vettenuts
Those are pretty big numbers for just a Blackwing and exhaust. Mine did 305 if I remember correctly. Which dyno was this?
Old Oct 28, 2007 | 09:50 PM
LTCHAPPA's Avatar
LTCHAPPA
318rwhp with blackwing and exhaust,then 330rwhp after tune on a Dynojet. TTPerformanc did the tune and the tuner said the car was putting down very good numbers.Headers are next and a re-tune. The HP gains do show up very well on the street i can assure you. LT
Old Oct 30, 2007 | 04:31 PM
simpleman68's Avatar
simpleman68
350 rwhp is doable, I agree with the above.
Nice color by the way. We should grab a brew sometime. My sweetheart lives in Little Falls, so I'm crusing past you often. I occasionally grab a few cold ones with another MSG owner in PA, just so we can park them together.
Scott
Old Nov 2, 2007 | 03:57 PM
wingnut037's Avatar
wingnut037
Nice #'s for sure. notice any difference in your gas mileage on the hwy? just wondering if its noticable
Old Nov 2, 2007 | 04:44 PM
LTCHAPPA's Avatar
LTCHAPPA
I think i may have picked up 1 or 2 mpg if im cruising on the highway.
Old Nov 2, 2007 | 06:56 PM
spiral04's Avatar
spiral04
I think those number are right on. I had longtubes, blackwing, and ghl exhaust tuned by LAPD at 355 rwhp. I don't remember the torque off hand but it was pretty close to the hp.
Old Nov 29, 2007 | 04:01 PM
CanadianVetster's Avatar
CanadianVetster
Default pre - headers
mine is a 2001 vert 6sp
same exhaust - corsa cat back
same intake - Blackwing
also used a hand tuner
Dyno shows 332 rwhp; 345 torque
I am also looking at Headers.
I would like Kooks, but the Dynatech are about $400 cheaper, then could spend the money elsewhere....... thoughts
To Dyno before Header install
