What about the torque tube? Still stock? What did you do to the suspension. It really squated. It cant be stock. How is this setup for daily? I have a 99 FRC that im thinking about doing a Cartek 427 in, but I could never go Auto because im not that deep into drag. Is the car still driver friendly on the streets if you so choose to take it out on the town?
Stock torque tube. Stock suspension except for QA1 shocks. I drive the car weekly but change the shock setting for street driving verses drag racing. The shocks are adjustable and can be set to feel like stock when driving on the street.
Wow Awesome run Im hoping to get into the 9s a 9.99 would be a dream for me...Are you running stock shafts...I have a 98 that I just put a 408 in and planning on about a 200 shot to get me to the 9s. Im sitting on CCWs and M6..Trying to get a DTE but they all seem to be Back order. Should be getting a Wolf cage Im only about 2 hrs or less from jackson...Maybe I will see ya around.
I hope you make it into the nines. I am running stock axles and a DTE stage 2 diff. My advise to you is to make sure that your drivetrain (trans, diff, etc) are strong enough to handle the 408 with the 200 shot. When you try to hook that amount of power to the ground you will soon find the weak link. Good luck. Jackson is a great track.
I got the diff out last night and just as I suspected, the ring gear was missing at least six teeth. Other than the pinion being trashed, I think that the rest of the diff is OK. Oh well, I've got all winter to fix it.
do you think it's a 373 problem ??? i went threw one ..billy one .... road rebel one... or maybe not cryoed ???
How do you set the QA1's for drag racing? I just bought them but have not installed them yet. Any suggestions will be appreciated!
I suggest setting both front and rear shocks in the middle (6) position to begin and for street driving. At the track you can adjust either looser or tighter until your times slow down. Each car is different depending on several variables such as power level, auto or manual, driving style, etc.
