Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Dyno with 100mm
Old Jan 26, 2008 | 04:55 PM
gojo's Avatar
gojo
Default Dyno with 100mm
Dynoed today at Williams Performance. The only change was the 100mm MAF. I'm not saying this proves anything since the increase is pretty dramatic. Map was 95 and now is 98kpa at peak power.
Look good?
Hp 447 to 470
Tq 411 to 437
Old Jan 26, 2008 | 06:09 PM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
Was the before dyno performed on the same day, and was there any tuning for the new maf prior to the after dyno?
Old Jan 26, 2008 | 07:20 PM
gojo's Avatar
gojo
The before dyno was done in November, I have the same AFR as then. We had tried more timing then but more timing didn't produce more power. This time +3 degrees over the previous timing added 9hp. Different days might cause some changes, but this is an awful lot and I don't know why or I might bottle it.
The new MAF needed a whole new set of values and it's still not right on the high end.
Old Jan 26, 2008 | 08:59 PM
TLewis4095's Avatar
TLewis4095
Originally Posted by gojo
Dynoed today at Williams Performance. The only change was the 100mm MAF. I'm not saying this proves anything since the increase is pretty dramatic. Map was 95 and now is 98kpa at peak power. If you go to Shutterfly view as a slideshow and select full screen.
Look good?
Hp 447 to 470
Tq 411 to 437
http://share.shutterfly.com/action/w...AcuWzhq1cslEwI
What throttle body are you running?
Old Jan 26, 2008 | 09:12 PM
gojo's Avatar
gojo
Stock TB. It's a totally stock crate LS7 except for ARH LT's. See my signature for details.
Old Jan 27, 2008 | 11:20 AM
TLewis4095's Avatar
TLewis4095
Very impressive! Try our Billet 90 & if you are not impressed w/the gain over the stock 90 I'll buy it back
Tracy
Old Jan 27, 2008 | 12:22 PM
gojo's Avatar
gojo
Tracy
Thanks TLewis. I don't doubt that your TB will produce more than the stock TB. I have some experience with billet TB's. Nick Williams used my car, with a moded 346and Fast intake to develop his 90mm. There was no question that more power was made. However, I can't describe how happy I am with the power of this engine and how driveable it is. When it was first installed the plan was to do some TB, intake and cam work this spring. I have changed my mind and it is staying totally stock. I can't floor it under 60mph on the street, now.
Old Jan 27, 2008 | 02:04 PM
TLewis4095's Avatar
TLewis4095
LOL! I have to agree.....you have a great combo most would be happy with. Enjoy!
Old Jan 29, 2008 | 09:42 AM
gojo's Avatar
gojo
I kind of got caught up in my own excitement. As I had mentioned we did 3 pulls. Nick nailed the AFR for the 2nd pull and then nailed the timing on the 3rd pull. I should have mentioned this.
Old Jan 29, 2008 | 10:20 AM
Former Vendor
Aye that would explain the good results, a maf alone should not provide a HP increase like that, Overall though, great numbers! You must be really happy with how that thing runs
Old Jan 29, 2008 | 12:34 PM
gojo's Avatar
gojo
If you go back and read what was done you'll see we ended up with basically the same AFR as the last dyno session and 2* more timing. In the last session it would not take more timing. This time 2* resulted in 9 hp more.
I tried it today from 60mph. Any lower and it spins. There is a definate bigger kick. Yes, I'm very pleased.
Old Jan 29, 2008 | 02:08 PM
vetterlatethannever's Avatar
vetterlatethannever
That's all that matters Great numbers!
Old Jan 29, 2008 | 02:16 PM
gojo's Avatar
gojo
JV,
Thanks, it's nice to get results that were unexpected, whatever the reason. I really don't make any claims, but it would seem that with these results and others I've read about, it's worth trying if it's for a big cube engine.
Joe
Old Jan 29, 2008 | 02:28 PM
blu00rdstr's Avatar
blu00rdstr
What MAF is that, is that the PowrMaf 100?
Old Jan 29, 2008 | 03:07 PM
TLewis4095's Avatar
TLewis4095
That's a good tuner Your in good hands.
Old Jan 29, 2008 | 03:50 PM
gojo's Avatar
gojo
Originally Posted by blu00rdstr
What MAF is that, is that the PowrMar 100?
http://www.lingenfelter.com/store/lp..._lpe-4232.html
It's Lingenfelter's. I bought it from Cajun4real.
I understand Bruce(Powermax) has a good one too.
Old Jan 29, 2008 | 10:12 PM
big hoss 98C5's Avatar
big hoss 98C5
To Dyno with 100mm
Old Jan 31, 2008 | 02:02 PM
gojo's Avatar
gojo
Originally Posted by big hoss 98C5
Exactly!
Old Feb 2, 2008 | 12:17 AM
Jersey_C5's Avatar
Jersey_C5
OMG You have the set-up I want....no NEED in my C5. I want to drop an LS7 in it sooooo badly.
Old Feb 11, 2008 | 09:38 PM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
Thanks for the links. I am ordering one from PowrMar...
