Bad 60ft times
My 03 z is making 418 rwhp with the 410's. The drag radials are 295 35 18 BFG.
I will not tell you guys my et or trap speed, the DA was about 4,000ft. I will say my trap speed went up by 4mph over last time out with LT's and stock gears. Pretty happy with that.
My best 60 ft was 2.0, was having trouble with traction. I know I should be in the 1.6 1.7 range. You guys with BFG, do you need to do a good burnout or just a clean off? I did not do much of a burnout. I was launching at about 3k, with a slip of the clutch. I think I would have been better off launching higher with a fast release. The car when stock was easy to get of the line.
You guys with gears and drag radials. chime in.
Thanks Brian
Thanks Brian
On a well prepped track you can come out @ 5000 and should be in the 1.5x's.
Being aggressive will yield the best times but you also run more of a risk of breaking something.
Goodluck and experiment and make sure you write down all the data.
Thanks Brian
If you don't want to launch so high the keep the tires @ 18 psi and launch lower but always do a good burnout.
I have a few video's of aggressive launches when I was making aroung 419rwhp in my z06 with 3.90 gears.
I think they were on et streets but it gives you an idea of how aggressive you need to be to get the low 60' times if you don't mind abusing your car. I'll try and find a link.
