Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
c5 computer check engine light
Old Jul 16, 2008 | 07:33 PM
fmbusby's Avatar
fmbusby
Cruising
New borla cat back and mass airflow sensor installed now check engine light comes on every so often . I did reset computer worked for a while but after new navigation system check engine light is on again . Plan to disconnect battery again to see if it helps, any suggestions
Old Jul 17, 2008 | 08:53 AM
simpleman68's Avatar
simpleman68
Should be in C5 tech.
Navi is aftermarket yes? Otherwise you need to be in C6 tech.
You need to run a list of codes to help us out more here.
Clear the DIC and while holding down "options" button, press "fuel" button 4 times and your pcm codes will be listed.
Without more info, we're flying blind here.
Scott
Old Jul 24, 2008 | 06:02 PM
fmbusby's Avatar
fmbusby
Cruising
ok thanks
Ill try that see if code appears
Old Jul 25, 2008 | 11:37 AM
simpleman68
Originally Posted by fmbusby
ok thanks
Okee. PM sent.
Scott
To c5 computer check engine light
