Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Mustang dyno numbers
Old Sep 4, 2008 | 08:33 PM
corvettefreak16's Avatar
corvettefreak16
Default Mustang dyno numbers
Put my car on the dyno at my school. Car made 344hp before weather corrections and 384hp after weather corrections does this sound right with my mods? Vararam, ls6 intake, borla x-pipe, and borla catback. will post graph as soon as possible. car is a 97 6-speed with 92k
Old Sep 4, 2008 | 08:51 PM
pit-man's Avatar
pit-man
Sounds pretty high to me for a MD...?? A 2003 zO6 with Vararam and tune is usually around 370 rwhp corrected on a Dyno Jet... I think...but maybe I am wrong ??? Anyone ?
Pitt
Old Sep 4, 2008 | 09:57 PM
kjmj's Avatar
kjmj
are you sure it was corrected the right way?
Old Sep 4, 2008 | 10:03 PM
TWOBUELLS's Avatar
TWOBUELLS
seems high for your mods , can you post your dyno print out ?
Old Sep 4, 2008 | 11:06 PM
corvettefreak16
The dyno is suppose to have a built in weather station that corrects for air temperature, humidity, elevation and a few other things i cant remember. Don't have a printout yet printer was not hooked to computer at the time but we did save the data from all the runs so it can be printed later. We had a 07 mustang on the dyno earlier with a
D1 procharger, 38lb injecters, side exhaust and tune and it made 466hp corrected which he said is about right.
Old Sep 5, 2008 | 08:21 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
My A4 2004 with headers, x pipe, tune, intake, and exhaust only made 338 at the wheels on a mustang dyno corrected for weather.
seems a little high.
Old Sep 7, 2008 | 09:16 PM
OneBadCEZo6's Avatar
OneBadCEZo6
Did he run it in.. Dyno-jet Mode? There is a mode on the new one's that simulate that.. But, Its done on a mustang dyno.. and Ppl tell every-one them numbers and it dont add up: Thats Why... Just from what I know
Old Sep 8, 2008 | 05:21 PM
corvettefreak16
Not sure. I will ask tommarow when i see him.
Old Sep 9, 2008 | 12:42 AM
C5XTASY's Avatar
C5XTASY
You are way high for power numbers with those few mods. Plus, your SAE correction also appears to be way off.
Ed
Old Sep 9, 2008 | 12:10 PM
N4cer's Avatar
N4cer
Those numbers are so high it's silly.
Plus, remember a Mustang doesn't necessarily read lower than others. It is more of a variation from one individual dyno to another... not brand to brand. I know my tuner's dyno consistently reads about 10% lower than other DynoJet machines.
Old Sep 9, 2008 | 07:19 PM
Impulsive's Avatar
Impulsive
You might do a little research before you stick with that opinion.
This link is a good place to start.
http://forums.corvetteforum.com/show...829&highlight=
Old Sep 9, 2008 | 08:38 PM
N4cer's Avatar
N4cer
Don't count on it. I'm Familiar with the theories and that doesn't change how it pans out in real life. Theory is for bench racers. Reality is for car guys. Thanks though.
Old Sep 9, 2008 | 10:26 PM
Impulsive's Avatar
Impulsive
In real life the major difference is with the dyno operator. The operator can make the numbers read whatever they want. Physics ( theories ) are correct and will give you correct outcomes if you can eliminate the operator differences. I 'm not a bench racer by no means. I go after the track numbers rather than the dyno numbers.
Mustang Dynos tend to have better repeatability from dyno to dyno since the are a direct measurement of torque instead of a mathematical formula with too many variables that change outcomes from dynojet to dynojet. I actually like what I am doing on the track with my Mustang dyno numbers.
Old Sep 9, 2008 | 11:27 PM
N4cer's Avatar
N4cer
I do agree that Mustang dynos are more consistent from machine to machine IF you can get the operator to not skew the variables. And if you mean running better times than others who have higher dyno numbers, that's awesome. I prefer that as well. I get sick of seeing the dyno kiddies on the boards claiming 500rwhp from a H/C setup but can't hit 11's.
Old Sep 9, 2008 | 11:34 PM
Impulsive's Avatar
Impulsive
Old Sep 9, 2008 | 11:37 PM
geterdone's Avatar
geterdone
The key is to get a operator of a mustang dyno that you can trust and won't just give you high numbers to make you happy. I would rather want the truth than some wacky numbers.
Old Sep 10, 2008 | 12:03 AM
Impulsive's Avatar
Impulsive
Most Mustang numbers are normally lower. From what I have seen, Mustang dyno owners use them for more accurate tuning rather than handing out high numbers. I wouldn't let anyone tune on my car without using a loadbearing dyno as I could care less about peak numbers. I look at the entire curves.
To Mustang dyno numbers
Old Sep 10, 2008 | 07:28 AM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
numbers are too subjective, take it to the track for a real number.....the cars trap speed is a good gauge of how much power you are really making.
Old Sep 10, 2008 | 08:34 AM
C5XTASY's Avatar
C5XTASY
[QUOTE=Impulsive;1567044583I could care less about peak numbers. I look at the entire curves.[/QUOTE]
My thoughts, exactly. Power under the curve is where it's at, IMHO.
Ed
Old Sep 10, 2008 | 01:07 PM
N4cer's Avatar
N4cer
Ed
Since your curve is the distance of your shift extension or how far you drop between gears, just gear your car properly (duh I'm sure everyone knows this) so that your peak IS in the curve. Pretty basic stuff.
