Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Mustang dyno numbers
Old Sep 10, 2008 | 01:17 PM
Mark-44's Avatar
Mark-44
Originally Posted by EVIL_C5
numbers are too subjective, take it to the track for a real number.....the cars trap speed is a good gauge of how much power you are really making.
Old Sep 10, 2008 | 03:32 PM
C5XTASY's Avatar
C5XTASY
Originally Posted by N4cer
Since your curve is the distance of your shift extension or how far you drop between gears, just gear your car properly (duh I'm sure everyone knows this) so that your peak IS in the curve. Pretty basic stuff.
This is true, but my thought concerning "area under the curve" was the actual total horsepower curve. Big peak numbers are fine, but greater power all the way up (i.e. fatter power curve), even at the expense of a big peak number, results in a much more streetable machine. I like big power down low, through the midband and at the high end. Damn, I want it all!
Ed
Old Sep 10, 2008 | 03:46 PM
Impulsive's Avatar
Impulsive
Ed
Well said. Some people just don't understand the power under the curve. As far as shifting to keep your self in the curve, I do like have my power come on well before 5000 rpm. The cam I have produces good gains over the entire curve on both hp and torque. It never falls back into the stock curves. Not even on the low end. MPH is a good way to measure hp. Mine varies from 114 -118 mph depending on weather. My best times have come from lower MPH runs.
Old Sep 10, 2008 | 04:02 PM
N4cer's Avatar
N4cer
Ed
I understand. So it's wording. YOu said "under the curve" when you mean "throughout the power band". They're different. The curve is the gear range. After all, who is unable to downshift? If so, you better get your tranny fixed! LOL!
I've noticed this trend over the past few years. The trend is to think it's faster to have a wide power band despite having much narrower gears. People talk like they are hammering their car from 1500rpm and wanting to outrun people. If that worked, we'd have only 6th gear and no others.
Old Sep 10, 2008 | 06:18 PM
Impulsive's Avatar
Impulsive
Actually its not a wording issue. The power curve and refering to the power under the curve all relates back to math. The measurement of a dyno doesn't look at measurements through all gears. The manual cars are actually measured in one gear. This leaves 1 power curve and 1 torque curve. The power band would only be a section of that curve.
Having a flat hp curve will leave you with a small power band which may or may not be able to be held since rpms could easily drop below when shifting. Changing the final drive gears will not always cover the gaps and could leave you with car not worth driving on the street.
Having a nice arc to the curve leaves you power through out each gear and gives you a wide power band. This is real nice for street driving and any type of racing. This is how that trend is making cars faster with lower peak numbers.
All the gear shifting you like is just how you utilize the power thats there.
