Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
rob z car does 9's again
Old Nov 21, 2008 | 08:30 PM
paint it black vette's Avatar
Default rob z car does 9's again
another 9.98 this time tommy from anger management was driving.after hitting a 10.02 first time down tom did burnout for second try. pulled upto lights launched snap broken output. we pushed car back to pits and tom had a shaft out of another car that had blown rear earlier ,robs shaft out and the other in about 10 to 12 minutes and then went back and ran the 9.98. amazing effort that change was worthy of a 9's slip. done with hand tools and one battery impact drill you and troy de mens
Old Nov 21, 2008 | 08:39 PM
Tsab's Avatar
Tsab
That 9 sec pass was da Sheet man. Astounding
Old Nov 21, 2008 | 08:41 PM
pit-man's Avatar
pit-man
Un frickin real !!!!!!!!!!!!!!!!!!
Pitt
Old Nov 21, 2008 | 08:54 PM
vetteboy2k's Avatar
vetteboy2k
Hey Rob.... next time do I get to drive also!!!
Old Nov 21, 2008 | 09:48 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
very cool.
Change a shaft in the parking lot. gotta love it.
Old Nov 21, 2008 | 09:58 PM
Rocktanski's Avatar
Rocktanski
Man that car just cooks.
Old Nov 21, 2008 | 11:42 PM
Rob Petyo's Avatar
Rob Petyo
Congrats AMR!
Old Nov 22, 2008 | 06:31 AM
pit-man's Avatar
pit-man
2 different drivers, on different nights, run the same record breaking time with one car.
That has to be another record to go with the 9 !!! You guys can drive, that's for sure. I salute you 2
Pitt
Old Nov 22, 2008 | 07:37 AM
vsocks1's Avatar
vsocks1
Cool! Was the shaft that broke hardened? Is Rob's rear built or stock?
Old Nov 22, 2008 | 07:51 AM
robz's Avatar
robz
The left axle half shaft broke. It was a a part that was damaged in the past.(don't ask)
Tommy built the rear, not sure.
Old Nov 22, 2008 | 09:35 AM
DBN's Avatar
DBN
That's pretty cool.
Old Nov 22, 2008 | 02:49 PM
Fartpipe's Avatar
Fartpipe
Congrats to both of you...... it was a half shaft then not a output shaft???? Changing a halfshaft in 12min's is damn impressive! Changing a output shaft in 12min's is well not sure what you would call it but scarey!!!!! IMO! LOL!
Old Nov 22, 2008 | 04:14 PM
if you check around on the computer on some vendor sites some call it output shaft and some call it half shaft. either way whens its broken you got the shaft.
Old Nov 22, 2008 | 05:53 PM
Tsab's Avatar
Tsab
Its Still over in a trash barrel at Atco Raceway if you want it......
Old Nov 22, 2008 | 09:43 PM
that was good tom you and me you 9's me 10's you go first and get some good rubber on track for me
Old Nov 22, 2008 | 09:56 PM
vetteboy2k's Avatar
vetteboy2k
http://www.youtube.com/v/FzLHN0TTbI8&hl=en&fs=1
Old Nov 22, 2008 | 10:09 PM
Fartpipe's Avatar
Fartpipe
GOSH DAMN! That kicks a automatics azz at shifting IMO!!!!!!!!!
To rob z car does 9's again
Old Nov 22, 2008 | 10:20 PM
robz's Avatar
robz
That's how Tommy rocks.
Two different drivers, two different techniques, two different days..............
SAME RESULTS.
Old Nov 22, 2008 | 10:22 PM
Fartpipe's Avatar
Fartpipe
What was the temp out that day down there? I'm debating going to cecil tomorrow but the high is going to be around 37-39deg's and i'm afraid of what the top end of the track is gonna be like. Atco preps their track alot better then most and this was a rental so they probably sprayed the entire track to make sure you guys were safe
Old Nov 22, 2008 | 11:02 PM
robz's Avatar
robz
Atco did an amazing job thanks to Joe Sway, Kevin, and Brian.
The temps were 35-38 with intermittent flurries and a 29.99-30.04 barometer.
The air got much better by 4:30 on as the barometer went up, the skies cleared and the wind died completely.
The evening session had it best with great prep, rubber, air, and all the runs runs they wanted for $15.
