Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Finally some dyno results
Old Feb 18, 2009 | 09:36 PM
Ragtop99's Avatar
Ragtop99
Default Finally some dyno results
Here is a combo:
Total engine airflow Ls6 stage 2 ported heads
ported 90mm fast intake
Ls2 TB
30lb injectors
Dynatech full exhoust with highflow cats
.595/.579 cam
2800 stall converter (VIG)
3.42 gears
Car made on the dynojet dyno 417hp and 386torque
My question is am I in the ballpark or is something off?
Old Feb 18, 2009 | 09:39 PM
j0n's Avatar
j0n
Originally Posted by Ragtop99
Here is a combo:
Ls2 TB
30lb injectors
.595/.579 cam
3.42 gears
Dyno should be used simply as a tuning tool. Don't worry about the numbers. Take it to the track and see what kind of trap speed it's turning before worrying about anything being wrong.
Old Feb 19, 2009 | 06:21 AM
PRE-Z06's Avatar
PRE-Z06
seems a little low, was the converter locked and what's the duration of the cam?
Old Feb 19, 2009 | 08:11 AM
DA GOAT!'s Avatar
DA GOAT!
Doesn't seem low to me. Looks good!
Old Feb 19, 2009 | 08:49 AM
nickolbag's Avatar
nickolbag
Seems like its in the ballpark.
Old Feb 19, 2009 | 12:04 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
It depends on the specs on your cam. I'm guessing you went with a rather mild one, correct?
Nice numbers, though. And if it drives the way you want it too, then that's all that matters.
Old Feb 19, 2009 | 03:43 PM
JohnStuttle's Avatar
JohnStuttle
Do Not Quench The Spirit
St. Jude Donor '13,'19 thru '26
Probably in the ballpark seeing as you don't have long tubes. Add the longtubes and you should be at 440+. I am shooting for 450 - 470 on about that same combo with long tubes through a M6. Car should be done in a couple of weeks.
Old Feb 19, 2009 | 05:38 PM
pit-man's Avatar
pit-man
Plus remember you are reading from 5-6 % lower than a manual tranny would. That's 20+ hp
Pitt
Old Feb 19, 2009 | 05:51 PM
Ragtop99's Avatar
Ragtop99
Actually I have long tubes and the specs on the cam are as follows
lift .595 .579
duration @ .006 tappet lift 281 289
I'm not very good with cams but I was told its preatty decent size. As to converter being locked I trully don't know I just droped off the car at the dyno and picked it up the next day. They didn't inform of any problems wih the car ather than they thought the converter was a little small for the cam.
Old Feb 19, 2009 | 08:02 PM
sami85L98's Avatar
sami85L98
Dont know @.050 what duration would be but seems like cam is little small i could be wrong, definetly u low on power i would expect atleast 430 Rwhp and 400 Rwt, but u have a auto they have more drivetrain loss than manual cars. But again u also have 3.42 gears which is little more than for auto (nothing wrong with it just reads ~5 hp low).
Also is that dynojet or mustang dyno, if mustang dyno than those #'s are just perfect.
Port the LS2 TB if its not ported yet, another 5-10 hp.
If the car drives good and u r happy just leave as is and enjoy the mods, at the most u r losing 10-15 Rwhp thats not big difference tho.
To Finally some dyno results
