Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
What do you all think this setup would run?
Old Mar 21, 2009 | 08:51 PM
OCMDMike's Avatar
OCMDMike
Default What do you all think this setup would run?
98 A4 Coupe
3.42 gears
3200 stall
Vararam Intake
LS6 Intake Manifold
Kooks Long tube 1-7/8 headers
cat delete
Z06 ti exhaust
mild to moderate cam
upgraded valve springs
also, what do you think the above would do with a 125 shot on top of everything?
I'm hoping to get low mid 11's off the bottle and maybe mid 10s on the spray. Think this is realistic?
Old Mar 21, 2009 | 09:46 PM
nickolbag's Avatar
nickolbag
I'd say 11.2-11.3 NA.
Old Mar 21, 2009 | 09:59 PM
Blow Torch's Avatar
Blow Torch
11.6 to 11.8 NA on street tires; high 10s on spray maybe.
Old Mar 21, 2009 | 10:29 PM
Wickd1's Avatar
Wickd1
11.5 na
Old Mar 22, 2009 | 08:42 AM
WKMCD's Avatar
WKMCD
11.8-11.9. Mostly due to the TC
Old Mar 22, 2009 | 10:39 AM
OCMDMike's Avatar
OCMDMike
what would I need to go higher?
Old Mar 22, 2009 | 10:47 AM
danielf's Avatar
danielf
Default Lots To Consider !!!
Mike on your post there are a few other things you must consider into the #'s . Track location and elevation. Weather and humidity, and track temp/air temp.
I'm running pretty close to your same basic set-up but with Z-06- 243 heads and cam. On drag radials , in good air and temp. I can run 11.98 @ 114 mph Still have to work a bit more on better 60 ft times I think 1.70 60' , but still with slight tire spin and room to improve.
Track prep and conditions will play a big role on if you can let out a great 60 ft time. But its great trying , Take Care and good luck
Old Apr 3, 2009 | 03:18 PM
OCMDMike's Avatar
OCMDMike
Update: just ordered a 3600 yank. looking for the gears right now. Would mid-low 11's be unrealistic?
Old Apr 3, 2009 | 08:06 PM
pit-man's Avatar
pit-man
Plus what tires ? Air pressure ?? Launch RPM ? What is your RWHP\TQ ?? How much cam ? Open headers or closed exhaust ?
To What do you all think this setup would run?
