Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Sprayed it tonight!
Old Apr 19, 2009 | 01:03 AM
DA GOAT!'s Avatar
DA GOAT!
Default Sprayed it tonight!
Well I got the NOS kit hooked up and the bugs worked out, except the upgrade on the fuel system I now need, and it all went well. Started the day off going to Williams Performance to get the nitrous tuned in. Found out real quick that my 125 shot became a 70 shot! Had to jet the fuel side way to high to support it (NOS 55 nitrous jet, 47 fuel jet). Dyno ended up with 511/497 with the A/F about 11.5 to be safe. Mind you I'm still on a bone stock tranny! Set the FJO to come in at 50% @ 3400 RPM's and ramp to 100% @ 4000 RPM's. First pass I peeled off a 6.91 @ 101. Second pass I changed the ramp rate to 75% @ 3000 RPM"s, blew the tires off and run a 7.0 @ 100. Last pass, with the bottle going low, ramped it in to 100% at 3000 RPM's and squeaked out a 6.83 @ 100. With a built tranny and the right fuel mods it will run 6.50's EASY in the 1/8th on a 125 shot! Cool thing is that it leaves oh so smooth! (tranny is living on borrowed time!)
Keep watching Blu!!!!
Old Apr 19, 2009 | 07:43 AM
pit-man's Avatar
pit-man
Runnin strong for sure !!!
Old Apr 19, 2009 | 07:50 AM
Kurtomac's Avatar
Kurtomac
nice job...whats your setup? Auto or stick?
Old Apr 19, 2009 | 08:45 AM
DA GOAT!'s Avatar
DA GOAT!
Auto. Mods are in my sig.
Old Apr 19, 2009 | 09:12 AM
tail_lights's Avatar
tail_lights
Very nice man, what tires are you hookin that up with?
Old Apr 19, 2009 | 09:19 AM
Kurtomac's Avatar
Kurtomac
damn you auto guys....nice job man
Old Apr 19, 2009 | 09:45 AM
DA GOAT!'s Avatar
DA GOAT!
MT ET Street Radials 305/35/18 and they hook like hell!
Old Apr 19, 2009 | 02:18 PM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
Nice #'s!! Is you kit wet or dry? Reason i ask is b/c I just found out my 125 wet kit was only about 90whp, running very rich. I had to lower my fuel jet way down to get my AFR right, but did not have any larger nitrous jets to get the hp up. I am running a Zex 30 fuel/64 nitrous. AFR was 11.8 (still a little on the rich side), and my gain was ~90whp/115tq.
Old Apr 19, 2009 | 02:31 PM
j0n's Avatar
j0n
Dry kits don't have a fuel jet, so his kit is a wet system.
Old Apr 19, 2009 | 03:03 PM
cmb396's Avatar
cmb396
CI 7-8-9-10 Veteran
Old Apr 19, 2009 | 04:44 PM
DA GOAT!'s Avatar
DA GOAT!
It's a wet kit (NOS LS2 Plate). We chased the fuel around and around! I kept having to go buy jets but we got it dialed in. Ended up with about a 70 shot when it was all said and done (NOS 55 nitrous and a 47 fuel). Picked up 68rwhp and 105rwtq on the dyno and a little more than 4/10ths at the track. I just need my tranny to hold through Pinks next week!
Old Apr 24, 2009 | 07:48 AM
DA GOAT!'s Avatar
DA GOAT!
Another best last night - 6.76 @ 103!
Old Apr 24, 2009 | 07:53 AM
pit-man's Avatar
pit-man
Solid mid ten at worst !! Congratts
Old Apr 24, 2009 | 08:59 AM
Blu's Avatar
Blu
Oh Im watching
Congrats on the new best, I don't think I'll be back racing until fall. Definitely don't want to break again until after the summer and I get to drive the car some.
103 is rolling pretty good, I hope Im over 100+ consistently after the new clutch and headers.
Old Apr 24, 2009 | 01:09 PM
JDaniel's Avatar
JDaniel
St. Jude Donor '08-'09
Wow! You will be in the mid 10's in the quarter with eighth mile traps like that! Awesome times!
Old Apr 24, 2009 | 03:16 PM
BonestockZ06's Avatar
BonestockZ06
Ha Ha, you say they hook like hell, but you peeled off on the first pass and blew the tires off on the second...
All jokes aside, those are some nice numbers. She's Hauling azzzz...
Old Apr 24, 2009 | 04:23 PM
Blu's Avatar
Blu
Im guessing 10.51 @ 130 at Rockingham, so when are you going?
Old Apr 26, 2009 | 07:40 PM
DA GOAT!'s Avatar
DA GOAT!
Run a 10.69 @ 130 at the Pinks All Out. Crappy 1.61 - 60' but that's normal at Z-Max!!!
Old Apr 27, 2009 | 07:56 AM
Blu's Avatar
Blu
Hell with good DA it looks like you might be able to knock out a 10.3x if it hooks hard.
To Sprayed it tonight!
