Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
First 1/4's ever
Old Apr 26, 2009 | 04:17 PM
01Z0Sixx's Avatar
01Z0Sixx
Default First 1/4's ever
I got my 01 Z06 in october, already built, 418 stroker, kooks long tube headers and h-pipe, stock axle overs, 315/30/18 nitto nt01's(road racing i know) ran at 21#. Car is putting down 440rwhp/432rwtq. First time at the track ever. Here's my first few attempts at it. Be gentle :o
1st pass
60' 2.134
1/8 8.473
1/4 12.614 @ 120.08
2nd pass
60' 2.159
1/8 8.417
1/4 12.571 @ 121.86
3rd pass
60' 1.856
1/8 8.028
1/4 12.115 @122.79
4th pass
60' 2.046
1/8 8.163
1/4 12.250 @ 123.42
5th pass
60' 2.017
1/8 8.153
1/4 12.271 @121.85
Old Apr 26, 2009 | 04:21 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Very cool
Looks like you had a fun time.
What ever you did on run #3 keep doing
Old Apr 26, 2009 | 04:25 PM
01Z0Sixx's Avatar
01Z0Sixx
Thanks. I had a blast. Run three was good. Car should do 11's easy. I just need the experience.
Old Apr 26, 2009 | 04:32 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Yeh, practice is really important.
With practice I've gone from 12.97 to 12.21
And I still need to get better at launching - my best 60' is only 1.85
Old Apr 26, 2009 | 08:54 PM
slowtealz28's Avatar
slowtealz28
Not bad, your mph is good for low 11's. Just curious though, how is the car only putting down 440 at the wheels? The trap speed would be right around where it should be for that power, but I am curious on your setup.
Old Apr 26, 2009 | 09:08 PM
tail_lights's Avatar
tail_lights
Looks good man!! As long as you are having fun!!!!
Old Apr 26, 2009 | 09:33 PM
GARY2004Z06's Avatar
GARY2004Z06
Congrats.
Old Apr 27, 2009 | 02:52 AM
01Z0Sixx's Avatar
01Z0Sixx
Those were the numbers from the dyno I just did a month ago. Unfortunately I got little info on the build/tune when I bought the car. It is a Shirl Dickey 418, so I'm trying to track down some more info on it. What numbers would you expect?
Old Apr 27, 2009 | 02:55 AM
01Z0Sixx's Avatar
01Z0Sixx
Fun is what I am having. Thanks for the support!
Old Apr 27, 2009 | 02:58 AM
NavyBlueZ's Avatar
NavyBlueZ
Some different tires should definitely put you in the 11s. Those tiny, hard sidewalls aren't helping your 60ft at all.
Great traps though man. Sounds like a bad *** car
Old Apr 27, 2009 | 03:15 AM
01Z0Sixx's Avatar
01Z0Sixx
I'm already looking for a nice drag pack. Skinnies up front and some 345's to push me.
Old Apr 27, 2009 | 07:25 AM
slowtealz28
If I was personally doing a 400+ cube motor, I would expect 480rwhp minimum. It really depends on what top end you decide to go with. I wouldn't get too worried over dyno numbers, they are more of a tuning tool than anything. As long as you are having fun with the car, then that is all that matters. My car should be a lot faster than it is, and it would be if I let other people drive it, but I still have a ton of fun with it.
Old Apr 27, 2009 | 07:57 AM
pit-man's Avatar
pit-man
Those trap speed should support some 11.1-11-4's with that stock rear end. Keep it up ....with some good tires.
Mine was hitting 11.3's @ 120 with 434 rwhp.
Have fun
Pitt
Old Apr 27, 2009 | 01:37 PM
tail_lights
Old Apr 27, 2009 | 04:16 PM
98vettedave's Avatar
98vettedave
Not bad numbers for the first time at the track. Do you happen to know what intake,heads,headers and cam that your combo is running presently?A 418 is a nice size motor.You should be able to pull so rather hefty HP/TQ numbers with that bad boy.
Old Apr 27, 2009 | 08:46 PM
01Z0Sixx's Avatar
01Z0Sixx
I'm trying to get the sheet from the dealer, but if memory servers, Absolute Speed stage 2.5 heads, stock ls6 intake with halltech with K&N air filter, cam I dont remember exactly but it is a medium sized aftermarket. Harland sharp pedestal mount rockers. Ill hopefully hear from the dealer in the next couple days.
Also, the ad that ran with the car said 484rwhp. When i had it dyno'd the guy said i had bad carbon buildup and needed to run cleaner through and clean the intake. Possibly robbing me of ~25ish rwhp. Said there is slight detonation at high rpm's. I just ordered a pcv catch can to help with that.
Old Apr 27, 2009 | 09:14 PM
JCamaro's Avatar
JCamaro
catch can=smart man
Old Apr 29, 2009 | 07:39 AM
holley505's Avatar
holley505
Curious to see what cam you have also
To First 1/4's ever
