Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Hey u Auto guys
Old Jun 26, 2009 | 08:50 PM
pit-man's Avatar
pit-man
Default Hey u Auto guys
Give me some TRACK advice here: Gary...u hv an Auto
Info: I am running a 410 gear, Auto and a 3600 stall. I run thru the traps perfectly at redline in 3rd gear. My sixty foot is 1.54 but I am having to roll out of the hole. If I floor it from idle, nothing but a smoke show. Weight is about 3900 lbs without driver. Power is 465/450 tq.
Questions:
If I was to go say...373 gear, what will happen to my sixty foot ?
Would I then be able to floor it from idle to benefit from the stall ?
Any change in ET ?
Pitt
Old Jun 26, 2009 | 09:04 PM
paint it black vette's Avatar
i cut consistent 1.47 to 1.50 with 3.73 and 3600 stall traping 126 at about 5150 rpm right about where the hp and torque curve cross paths on the dyno chart
Old Jun 26, 2009 | 09:09 PM
pit-man's Avatar
pit-man
Are you able to stab the throttle from idle ? That sixty foot isn't hurt a bit on yours. How much torque are you dealing with ?
Old Jun 26, 2009 | 09:17 PM
flashing converter at about 2200 to 2400 foot to the floor. around 440 ft lbs . car with me 3250 also pull a little wheelie when i hit right
Old Jun 26, 2009 | 09:22 PM
pit-man's Avatar
pit-man
By flashing...do you mean you are brake stalling to 2400 and then foot to the floor on the tree ?
Old Jun 26, 2009 | 09:28 PM
yes. trying to get off brake as i bring up rpm to that good spot for me which is the 2200 to 2400 area. have hit a couple 0f times at2600 and the car launched real hard but spun just after i got going. probably if i dropped tire pressure just a little i might have got them to hook up
Old Jun 26, 2009 | 09:33 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
4500 stall here with 4.10 no reason you should not be able to hook at the track.
Are the tires shot? have you tried lower pressure? ET Street right? I used to run mine around 12.
I am running drag radials now.
going to 3.73 might be help some but not much...cheaper to go with a new set of tires.
Old Jun 26, 2009 | 10:42 PM
pit-man's Avatar
pit-man
I've tried ET Street Radials, Hoosier 10" slicks and the new Goodyear Drag Radials. They all go up in smoke from idle. You probably don't know we are talking about a truck here...not a vette. That light azz rear end won't stay planted too long. I am thinking it may take a gear change to calm it down but don't want to kill my ET.
Old Jun 27, 2009 | 10:10 AM
ALVETTE00's Avatar
ALVETTE00
LOL...when you said 3900 lbs i was thinking you were towing a trailer with Hooter Girls or something...
Old Jun 27, 2009 | 10:13 AM
ALVETTE00's Avatar
ALVETTE00
The Great PIB has spoken!
Old Jun 27, 2009 | 10:44 AM
mitchell c's Avatar
mitchell c
Questions:
Any change in ET ?
Pitt
If your rolling out of the hole and you are still running 1.54 60s with such a heavy vehicule. That is pretty good since you are probably at 4100 lbs. with you in the truck. Since none of the tires you mentioned seem to be doing the job. You might want to consider doing some rear suspension work such as different shocks and springs for starters.
Old Jun 27, 2009 | 10:53 AM
Kurtomac's Avatar
Kurtomac
let fartpipes fat lady friends ride in the back...should hook up then!
Old Jun 27, 2009 | 11:03 AM
nickolbag's Avatar
nickolbag
Talk to some suspension experts before changing gears. I'm sure there is some tweaking you can do to help you launch harder and hook up. Don't go crazy and start swapping gears before trying out the easy stuff first.
Old Jun 27, 2009 | 11:04 AM
Rob Petyo's Avatar
Rob Petyo
I would have thought running the 4:10's, you would have run too high rpms, huh, interesting . . . I was thinking about going with 3:90's but heard that was too much.
I have 373 gear with 4k stall and cut high 4's - low 5's 60' - haven't figured out the best "flash point" yet . . I have just decked the gas and had a 1.51 60', so go figure.
sounds like whatever your doing (controlling the spin) by feathering the gas might be the best you'll be able to get without going to different. gears.
Are you NOT happy with the 1.54? I think thats pretty dag-gone good!
Sorry if I didn't answer the question.
Old Jun 27, 2009 | 11:15 AM
sixspdvet's Avatar
sixspdvet
I have watched Pitt run a few times, the back of that truck drops pretty hard, and could never figure out why it won't hook...the only thing I could think of and I have not looked at it is it coming back up too fast causing the tires to unload.. Other than putting some Lead in the rear.... Just mu .02 worth
Ernie
Old Jun 27, 2009 | 11:50 AM
pit-man's Avatar
pit-man
Rear is set up with 4 link and QA-1's. I would need a Pro to help me out prob as Nick says below.
I'm happy with low 1.5's but staying consistant rolling out is hard. I vary a half a tenth. I want to be able to launch off idle as Ernie and I think I will see some mid 1.4's and that will get me my 10 second slip I am after.
Ernie
Here is some vids Ernie, maybe you can spot a problem ??
On slicks:
http://s160.photobucket.com/albums/t...Leavecheck.flv
On ET Streets:
http://s160.photobucket.com/albums/t...17mphMPEG2.flv
http://s160.photobucket.com/albums/t...b1117mpeg2.flv
It Plants hard:
Thanks guys.
Pitt
Old Jun 27, 2009 | 12:27 PM
GARY2004Z06's Avatar
GARY2004Z06
Questions:
Any change in ET ?
Pitt
Hey Pitt,
Thanks for the compliment. I usually try to stay out of giving advice on subjects that I have little experience. Having said that, Ernie makes a good point if you are indeed unloading that light rear. You may want to stiffen the front shock setting to slow down the rebound or slightly decrease the rate at which it transfers the weight to the rear. A porpoising effect will cause the rear to unload.
Just my 1 cent.
To Hey u Auto guys
Old Jun 27, 2009 | 01:36 PM
for sure you'd get a wheelie then and help the girls on there diet as they would absolutely ship? themselves
Old Jun 27, 2009 | 02:46 PM
pit-man's Avatar
pit-man
We could get a pic and photo shop them if they rolled out !!
Old Jun 27, 2009 | 03:36 PM
j0n's Avatar
j0n
