Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Drag radial questions
Old Sep 7, 2009 | 11:39 PM
tommie's Avatar
tommie
Default Drag radial questions
I am looking for suggestions...
I have some front c5 zo6 wheels to use for rears (drag radials) on my c5.
I was thinking about the nitto 555r drag radials 275/40/17.
my C5 is a manual, with 388/383 rwhp/tq stock trans and diff.
looking to lower my 60' times and my ET...
is this the best/safest bet? have heard that i should go with these, and they should work with the power that i am putting down...
Old Sep 8, 2009 | 12:09 AM
DragMan's Avatar
DragMan
Cruise-In VII Veteran
I would only run M/Ts DR's but thats me. Never had any luck with Nitto's with any power!
Old Sep 8, 2009 | 08:34 AM
simpleman68's Avatar
simpleman68
Almost any DR but Nittos. With a couple dozen runs, the best I could do was 1.8x and a lot of wheel hoppin'.
Scott
Old Sep 8, 2009 | 09:15 AM
ROJO99's Avatar
ROJO99
I am running BFG's right now and finally have the launch dialed in and I am able to get 1.7's. I am thinking with more seat time 1.6's should be not far away. I am running 18" on the rears also.
Old Sep 8, 2009 | 12:08 PM
pit-man's Avatar
pit-man
Scott
I agree ! I never had better than a high 1.7 (I think...too long ago).
The Nittos are great for the street.
Old Sep 8, 2009 | 06:59 PM
j0n's Avatar
j0n
If you want a drag radial the best bet is going to be the m/t radials. However, the m/t bias ply et streets will be softer on the rear.
Old Sep 8, 2009 | 07:21 PM
Stevo92z28's Avatar
Stevo92z28
M/T ET Streets. No other
Old Sep 8, 2009 | 09:45 PM
tail_lights's Avatar
tail_lights
Old Sep 8, 2009 | 09:52 PM
GARY2004Z06's Avatar
GARY2004Z06
I ran 275x40x17 Hoosiers on my bolt-on C5Z. I guess they worked out okay for me.
Old Sep 8, 2009 | 10:00 PM
tommie's Avatar
tommie
thanks for the feedback guys...
Old Sep 8, 2009 | 10:35 PM
PRE-Z06's Avatar
PRE-Z06
I believe they worked for robz and rattg too
Old Sep 9, 2009 | 02:42 AM
GARY2004Z06
You can say that.
Old Sep 9, 2009 | 06:35 PM
tommie's Avatar
tommie
http://www.summitracing.com/parts/HOO-17330/
are these the hoosiers your talking about?
can you drive on the street with these? to and from the track? and some night time fun?
$419.82 tire rack to the door on hoosier drag radials...
$427.85 summit racing to the door hoosier drag radials...
Old Sep 9, 2009 | 10:40 PM
PRE-Z06's Avatar
PRE-Z06
that's them, didn't realize they're cheaper from tirerack. I'll pass that a long to a buddy who's fixin to order them, thanks.
Old Sep 9, 2009 | 11:04 PM
99ZX9R's Avatar
99ZX9R
I had these and swapped them for M/T DRs. Sold them to a forum member (Capthuff) and he loves 'em. I believe they're a bit lighter than the M/Ts and felt a bit stickier to me. Downside is I think they wear quicker and have almost no tread so probly not very good in the rain. I did drive them on the street with no problems.
Old Sep 10, 2009 | 08:23 AM
GARY2004Z06
Also, DO NOT DRIVE THEM IN THE RAIN. I got caught in a downpour in my C6Z and it was a nightmare. I was forturnate to have my two friends, Mark and Kyle, trailer me to safety. For some reason, my C5Z was not as bad, but I still had a white-knuckle ride home.
Old Sep 10, 2009 | 12:34 PM
98vettedave's Avatar
98vettedave
I run on the same Hoosier DR's as Gary. Avoid the rain if at all possible...if you get caught in the wet your butt will definitely pucker up.
To Drag radial questions
Old Sep 10, 2009 | 05:12 PM
GARY2004Z06
I think mine was glued shut.
Old Sep 11, 2009 | 10:28 PM
socalzo6's Avatar
socalzo6
M/T or Hoosiers. stay away from nitto
Old Sep 12, 2009 | 08:22 AM
paint it black vette's Avatar
what did you use gorilla glue or pl500
