It just gets better!
Edit:
Decided to look it up......
coupe (with manual) - 3230/1465
coupe (with auto) - 3253/1476
convertible (with manual)- 3231/1466
convertible (with auto)- 3254/1476
hardtop (manual only) - 3174/1440
j0n has about 60lbs on you. All other weight reduction mods being equal of course. But the FRC came manual tracks(right???), if so you will close that gap. Everything else will probably be the same, unless he decides to lose some lugnuts.
A loaded 'vert might weigh up to 30 pounds more than a base model 'vert.
Most hardtops had very few options even available to them so they're usually pretty to close to one another in weight.
Capt, you have a roll bar?
I don't think that he does, and let's not say that too loudly either.
A new clutch along with a couple of other odds and ends and yes it could be possible in perfect air.
Shhhhhhhhhhh....
I might be shopping for one pretty soon too.
Even us auto drivers are smart enough to know that.
Yes there actually are some potential performance/ET benefits of a somewhat worn/slipping stock clutch but even in the best air (which also means more power, less traction with even more stress on that already taxed clutch) that car is not going 11.1s exactly as the car sits. Not with the likes of RobZ or Ranger driving and not even with the current C5 and C6 Z06 bolt on master himself behind the wheel.
But I'm still hoping that Pete will prove me wrong.
The ET gap between bone stock C5 LS1s (12.6x) and C5 Z06s (11.7x) is over 8/10ths yet somehow/someway that gap will suddenly shrink to only 3/10ths or less once both cars are equipped with similar bolt on mods? Equalized for tires (the stock C5 LS1 tires are inferior to the stock C5 Z06 tires) there is still at least a 5/10ths deficit in stock trim.
Yes, one bolt ons C5 Z06 has gone 10.8x (the next closest one being an 11.2x) but that still doesn't make Pete as good of a driver as that 10.8 car's driver.
The LS1 just doesn't have the kick that the LS6 does, nevermind that the Z06 is also lighter, slightly more aerodynamic and comes with (according to some at least) more preferable transmission gearing as well.
I know the ingredients it will take to get Pete's car into the 11.1s with just bolt ons but it's so very likely not happening as the car sits.
I stand by what I've already said, Pete has the potential to see 11.3s in that car with a new clutch and better air.
Pour another grand or two worth of bolt ons onto the car and he could go even quicker/faster as well.
And yes, I too know a little bit about bolt ons only Corvette performance as well.
Back on topic, damn good time I need to learn how to drive.
I ran a stock Z06 clutch for almost a season with a head and cam package at 443 RWHP & DR's with no problems........ for while at least.
I knew I shouldn't have sold you my old exhaust system.
I still have those ported heads when you're ready....
(yes it's almost not even worth mentioning LOL).
) because hey, it all adds up and every little bit helps.
And yes, my apologies to Pete for contributing to taking this a little off topic.
You are driving superbly. I hope you have set your goal so you can make plans to achieve it. I believe there is a high 11.1x in there. Keep us posted.
