Warning don't cheat on your tuner
now the fuel system got weak from my boost a pump or trash? so i needed a new fuel system called Steven over @ east Texas muscle cars and he said no problem bring her in ill fix it!may take a while but i will squeeze it in! well i decided i wanted to look around and get a cheaper deal and faster service so i called xtreeme hp in Dallas and they said easy 1 week tops and he said he would check the tune also so i agreed to pay him 1650.00 i paid 1500.00 down! after 3 months i Finlay got the car back and he tried to charge me 3600.00!!! for new computer! battery installing a crank sensor checking all the grounds he said i had a lot of problems.so i told him this is BS and he cut the bill down to 3000.00 total the car ran like ****!it had all kinds of codes
air bag abs traction you name it!power reduction mode crazy! so i called him and he said i needed to spend more $$$ to fix it. i took my car to Steven @ east Texas he checked it out and said it had a gmc Yukon computer in it !!!WTF!! so i called xtreeme in Dallas they said my computer was bad!! and he was sorry about the Yukon puter that he meant to change the Vin to corvette.he sent me my old computer back and i installed it the car ran better and most of the codes were gone he said it had the same run file as the gmc computer did so its OK to run. well it was slow so i went back to my tuner i trust Steven @ east Texas muscle cars he dynod it first to see how good or bad xtreem did and to no surprises it only made 454hp wow!WTF!!!so after a long time on the dyno many pulls Steven got it to make 600+ with no problems and it drives awesome again so like i have learned never cheat on you tuner if hes too busy its not greener on the other side i was running 10s why would i cheat!! well it cost me a lot of$$$ to cheat not worth it!sorry east Texas muscle cars thank for taking me back!!
Xtreme HorsePowerNorth Richland Hills
Last edited by Allthrottleandsomebottle; Mar 15, 2010 at 01:22 PM. Reason: No direct info to non supporting vendors......
Everybody makes mistakes and I'm ok with that. But intentional neglect, short-cuts and lies is not a mistake.
Glad she's running better for you now.
Scott
I did what I could to resolve it, which yielded no positive results.
Nothing more I can do except move on and be more careful in the future and choose some folks that will treat me right.
Anger Mgmt and ECS have been tremendous to deal with. When little bugs come up, like they do in the high horsepower game, they fix the problem and we both walk away happy.
Scott
Scott
Glad you found a new camp that cares about its customers as much as they do the fat checks rolling in.
now to turn up the wick some more and get some 9's out of that DD car!
Scott
OP,sorry to hear about the bad experience you had with another sh-- bag vendor. I think you speak for the majority of us. Being screwed over in the Hod Rod (modding) world is all too common...it's like buyer be ware...I fall on that list of dumb ***'s also.
The issue was oil shooting out of the catch can.
Tommy at AMR took care of the problem and went through several work arounds to stop the oil.
First concern was to do a leak down test, which came back excellent, so we knew we didn't have any internal failure.
One of the big issues was the baffles in the valve covers. They wouldn't clear the Yella Terras, so Tommy fabricated some that would work.
The catch can, from the old vendor was mounted improperly and the top was mashed down just enough to break the seal around the top.
Tommy put in a new catch can, properly mounted it and all is absolutely A1 with the whole deal.
I should also add that Tommy not only jumped all over the issue and got it corrected, but wouldn't charge me anything when all was said and done.
In my past experiences, the old vendor blamed me for whatever happened and charged the sheit out of me to fix it.
I remember the timing chain (LS2) that after 5k miles, stretched and sawed the oil pick up tube. I was told; "must've been a faulty batch"
Come to find out, it wasn't installed/shimmed properly. That little gem cost me almost $2k to fix.
Then there was the broken bell housing and 2 of the bolts weren't even all the way seated.
The list went on.
Scott
So when do you think that you'll be going out for some shake down passes? Whats your goal 10.50 or lower?
I'll be spending more time getting back into HPDEs. A total change of pace, but I think they're more fun and not quite so hard on the car.
Scott
Scott
sounds like fun!!are cars are fast enough already just need to enjoy what we have and save $$
when to many other hands touch it
It sounds like sabotage' - they probably used your PCM in one of their rides
anything more missing from the Vette!Thanks,Matt
