Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
--Looking For some HP--
Old Mar 29, 2010 | 11:49 AM
MFDL's Avatar
MFDL
Cruising
Default --Looking For some HP--
I have a 98 LS1 I really want to add some horses but not sure what the best way to go is .The car is stock right now should I go with a programmer or something else
Old Mar 29, 2010 | 11:56 AM
pit-man's Avatar
pit-man
cold air intake, long tube headers and a Real-Tune from a good tunner.
Old Mar 29, 2010 | 11:57 AM
simpleman68's Avatar
simpleman68
Welcome to the addiction.
I think it is important to outline your goals first and go from there.
Do you want a little extra kick for the street?
Are you going to track the car?
Then its a matter of budget and what you want to do and when. Horsepower is almost always added in stages for most folks. I thought I'd be happy with a little extra kick for the street and occasional track events. Then, I figured out I wanted more.
A plan is very helpful and will save you tons of $$ down the road.
Scott
Old Mar 29, 2010 | 12:07 PM
MFDL's Avatar
MFDL
Cruising
Im looking for a little more HP on the street to have some fun with
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Scott
These guys are right on the mark.
What are your goals?
"I want more power" is kinda vague...
Old Mar 29, 2010 | 12:19 PM
MFDL's Avatar
MFDL
Cruising
My goal is to get it somewhere or 400hp with out opening the engine
Old Mar 29, 2010 | 12:45 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Not likely going to happen with an LS1 or even an LS6. But I suppose it could
If you dont want to open your engine, bolt on a supercharger... that will work.
I have a friend with a stock LS1, stock exhaust. Just had ECS bolt on a blower and tuned it. 490 to the wheels through an auto...
Now he's going to do headers and maybe a cam...
Old Mar 29, 2010 | 01:25 PM
simpleman68
Air intake, headers, catless X pipe, a pulley, t-stat, and a tune should get you close, but adding 50 hp (14+% increase) is no small feat.
You may also look at adding a cam to the mix. Cam only my stock LS1 head put down 413rwh and 387 rwt
Again, you have to make a plan for where you want to be down the road, and that ain't easy. Almost everyone I've ever known to mod a vehicle wanted more power later.
If budget allows, do all your bolt ons + a tune in one shot. Play with it for a bit and you can always step up to a good head and cam package or go FI at a later date and add 150+ hp to your stock motor.
Scott
To --Looking For some HP--
