Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
drag radial question?
Old Jun 6, 2010 | 11:28 PM
bentley14's Avatar
bentley14
Default drag radial question?
i got a 275 40 18 street tire on the car now i have some 275 35 18 bfg drag radials will the size hurt me in power?
Old Jun 7, 2010 | 03:56 AM
hector88's Avatar
hector88
what do u mean hurt u in power? the only difference is that the 275-35 is a shorter tire.
Old Jun 7, 2010 | 07:25 AM
GARY2004Z06's Avatar
GARY2004Z06
Old Jun 7, 2010 | 08:23 AM
clemsondave's Avatar
clemsondave
Shorter tire will technically give you more acceleration if you can hook. It's like going to a taller gear. However, the contact patch will be less, therefore less traction.
Old Jun 7, 2010 | 08:43 AM
bentley14's Avatar
bentley14
sorry, i guess i was a little unclear, yeah thats what i meant since its a shorter tire would it slow me down that way
Old Jun 7, 2010 | 03:15 PM
GARY2004Z06
You should accelerate quicker with a shorter tire.
Old Jun 7, 2010 | 06:18 PM
bentley14's Avatar
bentley14
i have got a hp tune, do i need to go in a correct the tire size or would that matter?
Old Jun 7, 2010 | 06:29 PM
clemsondave
It will effect your speedometer/odometer slightly, but nothing else needed.
Old Jun 7, 2010 | 07:10 PM
bentley14's Avatar
bentley14
k thanks i wasnt sure if it would affect hitting the rev limiter or anything
Old Jun 7, 2010 | 08:52 PM
99vetteran's Avatar
99vetteran
I run the 285-40-18 Nt05r's, mine are just a little over 27 inches tall. My stock 275-40-18 is 26.6 tall. Just lest then 1/2 inch. The taller tire will help on the top end as long as you have the power, I had looked at a 275-35-18, but, like said above it just doesn't want to hook as well with the shorter side walls. Mine should be great now that I have a Z06 tranny with lower 1-2-3 gears, it will offset the taller tire for me. Yours will be somewhere in the 1/2" shorter which may not hook like you want. Will still be better then your street tires.
Old Jun 9, 2010 | 01:52 PM
LightFighter_GXP's Avatar
LightFighter_GXP
I run 305's and they do pretty good around 25 psi
Old Jun 9, 2010 | 10:56 PM
PRE-Z06's Avatar
PRE-Z06
the 275/35 will should actually have a greater contact patch than the 275/40 because the aspect ratio is lower and doesn't allow the tire to curve as much if mounted on the proper rim size which I assume is the stock one. The only drawback I see is the less sidewall to cushion the shock, but being a DR it'll be better than the street tire. Also it could possibly require an extra shift as it'll knock off a couple mph off maximum speed in each gear.
Old Jun 10, 2010 | 08:05 AM
99vetteran's Avatar
99vetteran
Pre, our cars sure look alike, everytime you post I think its me for a second. I know yours is a FRC, but, just fools me from time to time. I'm kinda partial I suppose.
Old Jun 10, 2010 | 07:26 PM
PRE-Z06's Avatar
PRE-Z06
haha, I actually run the same wheels you do on the street...get your windows tinted and they'll be even more alike!
Old Jun 11, 2010 | 09:55 PM
LightFighter_GXP
PRE and Vet......... all are cars will look a like I just got my new wheels in
I'll be running mix match rims at the track since the Mickeys are mounted on my chrome z06 rims
To drag radial question?
