2002 Z06
1. ARH 1 7/8" long tubes with 3"x3" ORX
2. Vararam CAI and Vararam powerduct
3. ECS BIG N/A Camshaft
dynojet sae numbers 428rwhp/365rwtq. Car pulls hard up top with peak power around 6750 rpm. Having my tuner email me the dyno sheet so i can post it. The tuner did a great job with the tune also. The car drives great and i saw a high of 27 mpg on the way home . Cant wait to see what she makes with some TFS heads and a FAST intake/tb combo.
Need to install a TICK master cyn in the car before i go to the track. The pedal was slow to come up on high rpm shifts before the cam and would get better when i changed the fluid. Now under 7k rpm shifts it sticks to the floor lol. I plan on going to Z06 FEST in sept at Bowling Green. Hope to get the TICK and find some DRs for the car by then.
2002 Z06
See ya in Bowling Green, rolling in just like this (except a new turbo on the Busa)
I had to laugh about the Harley. That is a fully dressed 10 second street bike. Last race he took out a jacked up Viper from 2 different roll speeds and then a dig. The guy wouldn't give up...lol
We had it at the track a few weeks ago and it hooked and stood straight up out of the hole. Funny as hell.
this cam/tune is a great setup for me. the car feels great on the street, sounds GREAT and really has a strong smooth pull to 7k. i am really looking forward to getting it to the track (drag but more so an open track event).
What are the spec's on your cam (if I can ask)? I have a 02 MN6 vert and basically did the same mods (LG Pro LT, 232/234,595/598 112) and pulled 408/381. Our numbers are close but you gained 20 hp over me. I am running HF cats, stock heads (241), and stock TI mufflers. That could be the difference. I'm running a different CAI but that shouldn't matter on the dyno. I did better on the torque side (which yours seems a little low from other numbers I've seen, no offence). Also, did ECS give you any estimated numbers on where the heads would get you?
I'm staying with the LS6 intake, $900 bucks for maybe 15-20 (if that) horses is not a big bang for "my" dollars (may port to which ever head I decide to buy). I may go with larger injectors as well.
no specs on the cam sorry. just talked to chris at ecs about what i wanted out of my car and this is the cam i went with. As for the torque i think this cam does not make a lot of torque. Send a few post of guys with this cam and they seem to be in the 360s to 370s rwtq at the wheels. I am not running cats either. I would guess a set of TFS 215 or AFR 215 heads would put in the 480rwhp range with a fast intake/tb combo. My tuner said he did not see any reason my car would not make 460-470s with a good set of heads based on what he saw with tuning this cam. He did suggest that i up my comp ratio with the heads to make up for the low end torque. My 1 7/8" headers could be causing some lowend torque loss but helping with high rpm rwhp numbers. Dyno room temps were a 103 degrees during tuning.
