mir loser decal
Can't vote until I know the rules.
I haven't decided what I am going to do for clutch #6 in four years. The clutch and shifter were both new to the track, shifting was smooth as glass on 3 runs. MGW shifters are the bomb !!
Tell ya what, just mail me the decal and I will post a pic for ya, with it on the back window of my clutchless POS !!
your car ate:
-stock clutch
-2 RPS
-2 McLeod street twins
what are the others?
Maybe its time to go to a sissyomatic?
What did it run on the 3 passes you did make? Let us know the carnage when you get it pulled and post some pictures
That sucks!
I was looking forward to meeting you at MIR. There's still time.
your car ate:
-stock clutch
-2 RPS
1 RPS twin
1 RPS single
2 McLeod Street twins
now need a new single = 6 clutches
I walked the track, VHT felt decent for 92 degree heat. I hadn't been on the track in this car for a year and a half. By the third run, it felt like it had only been 1 week away.
First run was without front skinny tires, real easy launch.
2.1 sixty with a 12.01 @ 85...she started swerving from tire mix
Second run:
4200 rpm launch
1.686 sixty on 15 psi hot, ET Streets
11.406 @ 123.16
Third run:
Tried to match psi, rpm and track prep
3200 rpm launch
1.573 sixty on 13 psi hot, ET Streets
11.223 @ 122.90 (about the same time as last year)
I have this run in HD with an outside camera. Came out awesome...nice smooth run, like a trip to the store...lol.
Forth run was aborted.
The DA was 2800+ and very hot out on the track. Jimbos 416 ran a 11.14 @ 129+...not sure of his sixty foot, 1.6 area I think. We tried to run against each other on the failed 4th run.
Pitt
Think I'm gonna switch my Mcleod master out for a Tic on the next round. If I put my peddle to the floor and lift my foot quick, the clutch peddle follows about a second later. That doesn't seem normal to me ?? The clutch burning smell was unreal too !!
Get a Tick master, get a Monster stage 3 or 4 clutch and just enjoy the car racing periodically. PREZ06 will hook you up after you give him your story and get you a clutch at a good price before the end of the week. Tick master either pick one up used or new slap them in this weekend for minimal cost under $999 with fluids and break it in. Come up and have fun!!!!!
I had my McLeod Street Twin rebuilt and also replaced the master cylinder with their improved version during the winter of 09. The clutch is still going strong. I just went out to the garage and tested my clutch peddle release,there is no peddle delay whatsoever...obviously something just wasn't right with your clutch from the get go. Best of luck with getting back into the game - maybe a good single disc for now - that should get you through MIR and beyond.
I had my McLeod Street Twin rebuilt and also replaced the master cylinder with their improved version during the winter of 09. The clutch is still going strong. I just went out to the garage and tested my clutch peddle release,there is no peddle delay whatsoever...obviously something just wasn't right with your clutch from the get go. Best of luck with getting back into the game - maybe a good single disc for now - that should get you through MIR and beyond.I sold my last one, and bought this one brand new again, flywheel and all, like I always do. What is the chances of 4 bad clutches ?? Like a reverse lottery
