Performance Results Dyno sheets, Timeslips, Track Records, Who has the Fastest C5 Corvette?
Please recommend a lightweight 17" wheel..
Old Oct 4, 2010 | 07:36 PM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
Default Please recommend a lightweight 17" wheel..
For drag racing.. thanks.
Old Oct 4, 2010 | 07:50 PM
tommie's Avatar
tommie
for front or rear? how wide?
how much $$$?
if cheap and for the rear use some c5 z06 fronts...
Old Oct 4, 2010 | 07:56 PM
Shirl's Avatar
Shirl
Want to put Hoosier DR's 275/40/17 on them (rears). So 17"x9/9.5" or 17"x10". Something affordable.. (not CCW.) Other option could be 16" I suppose. Thanks.
Old Oct 4, 2010 | 08:19 PM
tommie's Avatar
tommie
for a 17x9.5 a front c5 zo6 wheel would be the cheapest to find....
that is what i use with mt et streets 26x11.5 17
i found 2 used ones locally for $75 that were gm...they were chromed and the chrome was peeling...
Old Oct 4, 2010 | 08:54 PM
Shirl's Avatar
Shirl
Ok, thanks. I have a pair of thin spokes 17x8.5. Should I just use those?
Old Oct 4, 2010 | 09:16 PM
tommie's Avatar
tommie
you can use those too... there are some people on here that use them.....
Old Oct 4, 2010 | 09:31 PM
Shirl's Avatar
Shirl
Ok. Thanks again!
Old Oct 4, 2010 | 09:40 PM
paint it black vette's Avatar
recomended wheel width for 275x40x17 off hoosier site is 9" to 11" thats why you use a zo-6 stock front wheel which is 9.5" and not the coupe wheel which is 8.5".
Old Oct 4, 2010 | 09:50 PM
Shirl's Avatar
Shirl
This is what I was wondering.. it would work, but the sidewall would bulge and be very tall !
How about a 245 on the rears.. ?
Old Oct 4, 2010 | 10:40 PM
98vettedave's Avatar
98vettedave
I have personally run through three sets of drag radials (275 40 17) on 8.5" rims. I know that they are technically 1/2" narrower than the recommend rim size,but they worked fine for me. The one down side is a slightly reduced contact patch...less rubber laid down.
Old Oct 4, 2010 | 10:43 PM
GARY2004Z06's Avatar
GARY2004Z06
The 275x40x17 Hoosiers with the front Z06 wheels weigh in at 40 1/2 pounds. Excellent tire and is extremely aggressive which may bog your setup. You will need to keep them aired up. This tire can handle a substantial amount of power.
Old Oct 5, 2010 | 06:16 AM
PRE-Z06's Avatar
PRE-Z06
agreed, if you run them real low it could cause cupping, but going lower than 18psi shouldn't be necessary
Old Oct 5, 2010 | 07:16 AM
Fartpipe's Avatar
Fartpipe
I would recommend a old set of C4 ZR1 rims... certain makes of the ZR1 wheel were actually pretty light, you can get a 17x9 or 17x11 rim and they fit fine. Plus you can use some really nice wax on them to make your car go fast!
Old Oct 5, 2010 | 10:43 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
That's what I use.
Old Oct 5, 2010 | 12:22 PM
Shirl's Avatar
Shirl
Thanks everyone!
Old Oct 5, 2010 | 05:57 PM
2003VETT's Avatar
2003VETT
From: Still the Fastest (still running) Stock Bottom End Blown LS1/ 2010 ECS CC 10.50 CHAMP Hamilton, NJ
I Run M/T Drag Radial 275/40/17 on stock front thinspokes (17X8.5) doesnt bulge, works great. I have been running that way for 5 years. over 1000 passes, so yes, it works!
Old Oct 5, 2010 | 09:14 PM
Charles Cyrus's Avatar
Charles Cyrus
This is the package I looking at, lots of used C4 ZR1s out there!
Old Oct 5, 2010 | 09:24 PM
cyclerage23's Avatar
cyclerage23
Also, 17x9" off a 98-00 WS6 firebird are great, there lighter than the C4 "ZR1" style and not too hard to find. they are a polished aluminum 5 spoke rim.
To Please recommend a lightweight 17" wheel..
